very strange starting problem
Posted: Sun Feb 05, 2012 7:29 am
Hi,
I am really puzzled by a sudden starting problem my car has developed in the last 24 hours.
It started with the car doing nothing for a second or two when the ignition was held in the normal starting position - it would then start as normal.
The next two starts had a longer pause, with the final one being about 3 - 4 seconds before the starter motor sprang to life and the car started normally. Apart from that, all i noticed was that cranking seemed a little less lively than usual, but i put that down to the freezing temperatures.
Now, when I turn the ignition key, all the dash lights light up as normal, but nothing happens at all (the starter motor doesn't even kick in). If I am not mistaken, the fuel pump doesn't sound like it is priming either.
I have checked all fuses, and all is fine. I have also scoured the 'tech help' forum, and nothing even seems remotely similar.
Any ideas/help greatly appreciated. The car is a 1990 m20b25 coupe.
P.S. I had been working on my driver's door lock, and had had the mechanism out etc, as I had a strange central locking problem (lifting the door handle caused the car to lock itself). Could this be linked at all?
