Notchy steering
Posted: Thu Feb 02, 2012 10:39 pm
by twoscoops
Hi guys
I have just got a '92 325i convertible and the steering is pretty horrible. Really heavy at low speed and notchy when turning. I've changed the ATF which looked like water and that has improved things slightly but it is still bad. Steering also feels very light and twitchy from 60mph up.
Anybody got and thoughts as to what the problem might be???
Tim
Re: Notchy steering
Posted: Fri Feb 03, 2012 4:56 pm
by twoscoops
Anybody got any thoughts? Cheers
Re: Notchy steering
Posted: Fri Feb 03, 2012 5:19 pm
by sweep
Power steering pump?
Re: Notchy steering
Posted: Fri Feb 03, 2012 5:22 pm
by Jim320i
Checked the belt?
Re: Notchy steering
Posted: Fri Feb 03, 2012 7:26 pm
by twoscoops
Belt looks grand mate. Not sure about pump how would you check it ?
Re: Notchy steering
Posted: Fri Feb 03, 2012 10:25 pm
by Brianmoooore
Light and twitchy at speed suggests to me that the tracking of the front wheels might be toed out, so I'd get the string out and check the alignment.
You can't really check out the pump, other than by changing it. If that doesn't cure the problem, then it must be the rack, unless there's something very seriously wrong mechanically with the steering.
Re: Notchy steering
Posted: Tue Mar 13, 2012 4:09 pm
by twoscoops
Is the pump something that an amateur like myself can change easily or is it better dealt with at a garage?
What sort of price am I looking at to replace it?
Re: Notchy steering
Posted: Wed Mar 14, 2012 5:13 pm
by thebloosman
Could be sllight play in ball joints, and any wear on inner front tyres is a dead givaway.... Id say" It's definately the tracking!" I had this problem recently after changing TCA's, drive like it was on ice! Be worth getting it checked! Save your tyres...
