lsd oil.
Posted: Tue Jan 17, 2012 8:42 pm
by 321gazza
I have a lsd fiited on my 318i from a tech 1,325i, what is the correct oil to put in and how much
Re: lsd oil.
Posted: Tue Jan 17, 2012 9:36 pm
by Ajsingh
Bmw MSPA 75w-140. IIRC they take 1.4 litres? Or you can fill it until it pours out slightly
Re: lsd oil.
Posted: Tue Jan 17, 2012 9:45 pm
by Jimbob
If you can't get to a dealers then you can order Castrol B373 online.
Re: lsd oil.
Posted: Tue Jan 17, 2012 9:52 pm
by bss325i
Castrol SAF-XJ is also suitable.
Re: lsd oil.
Posted: Tue Jan 17, 2012 10:18 pm
by E30SPORTMAD
Millers LSD oil is also good and fill till it overflows out of bung
Re: lsd oil.
Posted: Tue Jan 17, 2012 10:23 pm
by Sanchez
Jimbob wrote:If you can't get to a dealers then you can order Castrol B373 online.
1.7 litres roughly.
http://www.opieoils.co.uk/p-712-castrol ... ae-90.aspx
Zone discount availible with the above im sure.
Re: lsd oil.
by alan1272
morris oils also do a suitable oil. i use it in my rally car.
Re: lsd oil.
Posted: Tue Jan 17, 2012 11:32 pm
by Blitz
Is that defentaly suitable for LSD's?
Re: lsd oil.
Posted: Tue Jan 17, 2012 11:49 pm
by alan1272
i think it is, i know of at least one person who runs B373 in their rally car, its a high grade mineral as opposed to a synthetic oil.
Re: lsd oil.
Posted: Wed Jan 18, 2012 8:05 am
by 321gazza
Many thanks guys.
Re: lsd oil.
Posted: Wed Jan 18, 2012 10:51 am
by Sanchez
alan1272 wrote:i think it is, i know of at least one person who runs B373 in their rally car, its a high grade mineral as opposed to a synthetic oil.
Sanchez,(time=1311083345) wrote:So can someone whos replaced a diff before give me some heads up on doing it myself.
Picked up a 3.91 LSD so gona clean it up n fit it.
decent trolley Jack, axle stands, a good 19mm spanner and 9 or 8mm allan key socket
first time doing one is a pain in the arse I can do them in under an hour all going well.
dont tighten the bolts up untill you have all 4 in there threads.
if you want a hand doing it give me a bell what oil are you planning on using?
Castrol B373 is the only oil ill use for an e30 lsd you can get it from eBay or opie oils
The above is a quote from a respected e30 owner, on here and other forums.
