what engine oil to put in because i dont know if its syntec
Posted: Tue Nov 01, 2005 5:38 pm
by miami325e
since i got the car from a stealer how would i know when its time for an oil change if it is running on synthetic or normall.is there a way you can tell the difference between synthetic oil and normal.and if i put in synthetic and it had normal will it blow the seals.
Posted: Fri Nov 04, 2005 1:51 pm
by oilman
Without having it chemically analysed, you'll never know. Speak to your Dealer, hopefully it was 5w-40 fully synthetic.
Simon
Posted: Sat Nov 05, 2005 12:30 pm
by oze30
can you mix synthetic and normal oil? And is 5w-40 normal?? Need to top my oil up, but not sure which one to use??
Posted: Sat Nov 05, 2005 3:18 pm
by oilman
You can, 5w-40 is normally either a fully synthetic or has synthetic content in some of the cheaper ones.
Simon
Posted: Sun Nov 06, 2005 3:59 pm
by chu346
I'm currently using 5w40 and get a rattle on start up.
It's a fully rebuilt and not long run in. Should I be using 10w40?
Posted: Sun Nov 06, 2005 6:29 pm
by oilman
What oil are you using?
Guy
Posted: Mon Nov 07, 2005 12:09 pm
by chu346
Valvoline 5w40 synthetic.
Posted: Mon Nov 07, 2005 12:57 pm
by Paul325i
10W40 semi is the best all rounder for the M20, most of them had mineral in from new.
If you're getting a rattly startup i'd check your valve clearances.
Posted: Mon Nov 07, 2005 1:32 pm
by oilman
Stick with 5w-40 for better cold start protection as 90% of wear occurs on start up.
As the other poster suggested, valve clearances may need adjusting.
cheers
Simon
Posted: Mon Nov 07, 2005 6:51 pm
by chu346
oilman wrote:Stick with 5w-40 for better cold start protection as 90% of wear occurs on start up.
That's what I was thinking.
I'll check the valve clearances when I get time.
Cheers guys!
