I NEED MORE POWER!!!
Posted: Sat Oct 29, 2005 12:49 pm
by Mrblonde
Hey guys finding it hard to find power increases for my 316i
Any help ?
Posted: Sat Oct 29, 2005 12:53 pm
by coldo
Join the club....
I started out with the intention of building a tire smoking 316i....
Then realised the cost:power ratio... i.e. lots of cost.. not alot of power.
I used to hate it when people said to me "put a bigger engine in" but in reality... they are right. :cry:
In my opinion.. pipercross panel filter with a drilled airbox is all im doing to mine... cost me Ԛ£30 in total, i rekon its made a slight difference at higher revs, butn nothing too drastic.
Good luck though, if you find any useful mods, let me know :D
Posted: Sat Oct 29, 2005 12:59 pm
by Mrblonde
Well surely theres the obvious!
I dont want to go to big so i was thinking maybe..........
Exhaust, manifold, plugs + leads, chip?, high lift cam?? i dont i know i used to have a nova sr which yes it was a chavs car but i can see why it was a rocket!!!!!
Posted: Sat Oct 29, 2005 1:02 pm
by Mrblonde
i would love to do like my friend and put it on a major slim fast diet!
but his car aint pratical for general road use!
Posted: Sat Oct 29, 2005 1:39 pm
by chip-3door
Same thing as a nova mate.
Why bother mincing around with a 1.2 engine when you can chuck in a C16xe out of a corsa, or a nova gte engine or an XE or LET etc.
Its more expensive to get power from a smaller engine and it means more revs normally which = less reliable.
Posted: Sat Oct 29, 2005 2:25 pm
by MrDazzle
Nobody needs more power;)
Well, maybe Schumacher does:p
Posted: Sat Oct 29, 2005 3:25 pm
by Brianmoooore
MrDazzle wrote:Nobody needs more power;)
Remember that the next time you're 3/4 of the way past an artic you're overtaking, and some pillock comes out of an unmarked turning or laybye, and turns towards you.
Posted: Sat Oct 29, 2005 3:49 pm
by MrDazzle
Playing devils advocate here but...
If you're hit head on overtaking it's usually (99% of the time) your fault. Poor observation is what it is. If you can't see far enough ahead to be sure it's safe you shouldn't be overtaking.
Posted: Sat Oct 29, 2005 7:03 pm
by Moofles
Mrblonde wrote:Well surely theres the obvious!
yeah you could do that, get you up to a mighty 120hp instead of 101hp maybe?
now that's why people swap engines :wink:
Posted: Sat Oct 29, 2005 9:29 pm
by tomstickland
Waste of time and money when you can fit a bigger engine. I doubt that that lot would make much of a difference anyway.
Posted: Sat Oct 29, 2005 10:42 pm
by m-dtech
more power to the warp core scotty... :P
Posted: Sun Oct 30, 2005 2:19 am
by MONSPORT42
Apart from the obvious induction/cam/exhaust mods, probably the best increase in performance on a 316 would be losing weight from the car. The E30 is heavy and the 316 is a simple 8 valve and not much of match for modern engines.
