converting rear brake lines to flex type
Posted: Sun Sep 25, 2011 6:42 pm
by E30k
hi all i want to convert my rear brake lines to flexable type from the t-bar to the small flex pipes i have read and had a look it looks like a nightmare fuel tank axle all have to come out doing it the normal way by going flex it sorts this all out plus could you let me know where i can get the kits or gear i need to do the conversion as most seem to be in the u.s.a
Re: converting rear brake lines to flex type
Posted: Sun Sep 25, 2011 8:24 pm
by daimlerman
You need a flexi hose to bring the brake lines onto the trailing arms.
If the hard line to the flexi is buggered(most are)I would suggest that you slice the rotten flexi as close to it's ferrule as possible,then use a 14mm socket to release it whilst holding the hard line with a brake pipe spanner.
When this fails to work
slice the front/rear at a convienient place,and replace the lot from that point rearwards....
