gearbox not engaging!
Posted: Sat Aug 27, 2011 8:08 pm
by hmuminovic
hi guys,
today i replaced my auto box for another auto unit! my e30 is a 320i. its a non-switchable auto box!
the problem is now, it will only start in park and neutral, which is normal, however when i shift into gears, the engine revs up propa, but i cannot get it to engage with gearbox to then engage to prop shaft!
what could be the problem?
Re: gearbox not engaging!
Posted: Sun Aug 28, 2011 2:06 am
by grantorino
Lack of fluid? Linkage incorrectly or not attached? You bought a second faulty transmission?
Posted: Sun Aug 28, 2011 11:49 pm
by hmuminovic
fluid is deffinelty fine! i cleaned it all out again today, used air compressor and cleaned through rad hoses too, which flushed everythng out!
could it be that the torque converter has slipped of slightly and not engaging witht the shafts? but wot i don't understand is it spins fine with flywheel, but will not go through gears!!!
Posted: Mon Aug 29, 2011 1:31 am
by grantorino
The torque converter drives a pump that circulates the fluid. When installing an automatic, the torque converter should be pushed fully into the bellhousing while you spin it prior to installation. Then bolt up the trans to the engine, then pull the torque converter forward and attach the bolts to the flywheel.
Posted: Mon Aug 29, 2011 1:48 am
by hmuminovic
Thats deffinatly been done!!!
But ive had enuff! Time to do da right thing n get a 325 MANUAL into it
