copper brake pipe size
Si316
Thu Oct 20, 2005 6:38 pm
can someone tell me the size of metal brake pipe used on our e30's. ive got to replace some of my lines for an mot. Im not at home so cant measure them myself or look in a manual.
Si
IG: Si316ti
2.0L M10, Twin carbs, big cam
Full send restoration in progress
coldo
Thu Oct 20, 2005 7:28 pm
Not sure of the diamiter, sorry.
But ive just had mine done, and make sure and leave yourself plenty time, we had to take the prop shaft, exhaust and fuel tank out just to replace a section! Not the easiest job in the world.
I will try and find out the size for you tomorrow.
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Thu Oct 20, 2005 7:39 pm
I think it's pretty much a universal size for most modern cars. I'm sure wherever you're gonna buy it from will know for sure.
Taylor.
Guest
Thu Oct 20, 2005 7:46 pm
As it's a euro motor it should be 3/16"(5mm) dia pipe with M10 fittings.
If you are replacing under the car then try to go for Nickel/Copper pipe, slightly harder than standard copper.
If you are doing it yourself you will need a pipe flaring tool.
Andy335Touring
Thu Oct 20, 2005 8:16 pm
or you could get them from the dealers ?
I think they come cut to the right length with the correct fittings/ends already on you just have to bend them to shape ?
Thu Oct 20, 2005 10:57 pm
Brake pipe only comes in one size for cars, 3/16" or 4.6 something mm.
Use copper nickel alloy (cunnifer) pipe. Only costs about Ԛ£7 for enough to do every line on an E30 and still have some left over.
Make sure you get metric fittings for it.
darren318is
Fri Oct 21, 2005 6:30 pm
si316 thats the nicest 316 ive seen what suspension is it running :thumb:
Si316
Fri Oct 21, 2005 9:11 pm
Nice one lads thanx very much for the replys.
The whole rear end is now in bits so getting to the pipes is not a problem.
They really really need doing too. very supprised and shocked its got through an mot.
Darren - Its lowered 60mm front and 40mm rear on a spax psx kit. thanx very much for the comment! :cool:
IG: Si316ti
