pagid pads
Posted: Mon Oct 17, 2005 10:44 pm
by JCB
anyone any experience of PAGID pads. i have been advised they are very disc friendly and worth the extra cost. I hae been told to be careful with the Ferodo DS2500/300 range and the mintex 1144/55 as they eat discs ??
opinions please...
cheers
Jonathan
Posted: Tue Oct 18, 2005 5:58 am
by mgarrett29
All depends on what you are using the car for. I have a Hartge H27 which I use a fair bit on the track and over the last 18 months have used all sorts of combinations. The Pagid Pads are ok for fast road and light track use but they wear fast on the track and do not give the stopping, at least in a car as heavy as mine.
The best combination I have found are Mintex 1155 with Zimmerman Discs. They do eat up the discs eventually but at least the Zimmermans are cheap and therefore it balances out.
If you have an M3 then they do a Pagid Blue which are surposed to be very good although I have not tried these.
A slightly cheaper way to do it would be to put Pagid Fast Road in the rear and Mintex 1155 in the front with Zimmerman discs all round.
Posted: Tue Oct 18, 2005 8:02 am
by Liam
There are Pagids and there are Pagids!
I imagine Jonathan is talking about their RS pads as opposed to the fast road stuff.
You can't get Pagid RS-14 (blue) for the E30 but RS-19 or the new RSS-29 (yellow) are available. These are an endurance pad and some Milltek cars run them as they'll last a whole season.
To my mind, there's no point spending more than Ԛ£100 on pads just to be kind to the discs as the discs much cheaper.
Posted: Tue Oct 18, 2005 2:21 pm
by JCB
i have an E30 325 but am running M3 discs. i need to get the balance between cost of pads and cost of discs. the pagid blue did seem very expensive. like you say - cheaper to wear out the discs !!
Posted: Sat Oct 22, 2005 2:54 pm
by davemullender
I'm running the Ferrodo DS3000's on my Milltek racer, cost me almost exactly Ԛ£100 for the front pair (running standard drums on the rear).
Circuit Supplies
Tel: 01525 385888
Front pad: SCP303R
Ԛ£100.69
Although I changed the pads halfway through the season it was only because I had a warped disk so wanted to keep them matched, pretty sure they'd have just about made a whole seasons racing otherwise.
Dave
Posted: Sun Oct 23, 2005 10:06 am
by Taffy
We have used the pagid's but found the Mintex better, 1166's will be fine mate or if you want to push the boat out F4r's which we used all season but they're not cheap and only lasted us 3 races / on normal circuits and 1 practice session at Oulton! They're about Ԛ£120 / set but really do give great bite. Have a look at Performace friction as well, very good quality pads
Posted: Mon Oct 24, 2005 5:40 pm
by 215m3
I have the rs4-2 pads in my brake set up. I have done 3 full track days and one evening andi am heavy on my braking. The pads have worn no more than 3mm and the discks less than 1mm.
Bear in mind i have a bbk prodrive alcon set up with 325mm discs on my track M3
Posted: Fri Nov 04, 2005 9:04 pm
by JCB
had a very interesting conversation with EARS motorsport today. they recommended EBC red stuff (they say the new ones just out are really good , they admit the old ones were crap !) at about Ԛ£80 a set they said they represented good value and wee very progressive wheras the mintex and ferrodo can be very agressive (all or nothing). they also recommended that for track day use there is not much point worry about the rears as they will not have mcuh work to do, especially as the car is stripped so there is very little weight at the back. they suggested that i would get better brake balance by doing this as often people have too much braking at the back which upsets the balance. all sounds very logical to me - what do you think ??
Posted: Sat Nov 05, 2005 2:35 pm
by 320Touring
hi, as this is a technical question, i'm gonna move to that section,
hope you dont mind
Posted: Sat Nov 05, 2005 4:40 pm
by Julian_Jules
Pagid Fast Road squeels a lot cold&hot on ATE Power disc.....does not have the bite I want ( but perhaps that on my car ) & emits a fair amount of dust.
Posted: Sat Nov 05, 2005 4:43 pm
by Julian_Jules
Posted: Sat Nov 05, 2005 6:21 pm
by Templ8e30
I have Pagid fast road pads and ATE power discs on my 2.7 and find that they are great even when cold.
When they warm up they can squeel a little but it's not very noticable.
They performed faultlessly when I went round the Nurburgring this summer and I managed some hot laps
I'd also recommend braided brake lines to improve pedal feedback.
Cheers,
Iain T
Posted: Sat Nov 05, 2005 6:23 pm
by m-dtech
ATE power discs and Ԛ£6 pads from euro.
For all the hassle in changing the pads cost peanuts.
Although 1 set per track visit
Posted: Sat Nov 05, 2005 11:21 pm
by Demlotcrew
m-dtech wrote:ATE power discs and Ԛ£6 pads from euro.
The issue is not in their life span, but how well they hold up against the heat!
Andrew
Posted: Sun Nov 06, 2005 9:25 am
by M5pilot
Demlotcrew wrote:m-dtech wrote:ATE power discs and Ԛ£6 pads from euro.
Andrew
They might be holding up against the heat the way he drives.....!......and some more (!).....ok one more....... (!)
Posted: Sun Nov 06, 2005 11:55 am
by Simon13
pagid fastroad pads are pony!
My mintex m1155 pads do not seem to be killing my ate disks.
I like these pads, might try the ferrodos next DS2500 though
Posted: Sun Nov 06, 2005 1:38 pm
by Taffy
Mintex 1166 / 1177 & F1/4r's are superb, Performance Friction 01's are also superb, i'd stick with one of these. I ran standard discs with 1155's and it was fine, anything above this is worthless unless you upgrade the discs / calipers
Posted: Sun Nov 06, 2005 1:59 pm
by nikos
Taffy, how can you run m3 disks on a 325? this is a 5 hub disk; and what calipers do you use? nikos
Posted: Sun Nov 06, 2005 2:36 pm
by Simon13
are we talking for road or track use taffy?! cos those mintex 66's and 77's are not road legal. My 55's are bad enough on a cold morning!
pagid pads
Posted: Sun Nov 06, 2005 2:42 pm
by stoic
Been watching this post with interest as I'm about to upgrade standard brakes on my 325 (to cope with occasional 50bhp NOS surges). What would you guys recommend for discs and pads, and should I also upgrade the calipers and brake lines?
Ron
Posted: Sun Nov 06, 2005 3:02 pm
by ian332isport
Pagid 'Fast Road' pads are very good if your car is primarily used on the road. They are certainly worth the extra over standard pads.
If you regularly visit the track, then there are better options, but people have different views on what's good or not.
In general, Pagid pads are very good.
Ian.
Posted: Wed Nov 09, 2005 1:59 pm
by lancelot
I have used piles of pads for road/track use. Here's a quick summary of my experiences, car is a track orientated e30 M3.
EBC Greenstuff - Nasty. Don't stop very well and have an appetite for disks.
Textar Std Pads - Road use only, limited performance use.
Ferodo DS2500 - Nice pad, v good stopping power, average wear on disks.(was my favourite pad with stock brakes)
Ferodo DS3000 - Very stoppy pad, harsh on disks and paintwork/wheels get eaten by the dust.
Mintex F4R - Nearly as good a stopper as the DS3000, expensive, but not too harsh on disks.
Mintex 1155 - Bit less stoppy than the DS2500, not harsh on disks - good rear pad.
Pagid Blue - Current pad, coupled to AP 4 pots. Very nice, stop better than the car ever did, no fade, no overheating, virtually no wear on pads or disks. Have been told that these should last at least a year of racing, so for track day use they should last ages. Quite expensive. Quite dusty.
HTH
Posted: Fri Dec 02, 2005 2:52 pm
by trackpig
pagid fast road and ate disks
good for road use
6-7 laps of croft without fade(pretty quick laps)
no fade around nurburging
nice price
