Ok I've a weird one. (not that an E30 with a fuel gauge problem is weird or even unheard of.)
Anyways, I have figured out why the fuel gauge shows the needle being empty (no light on) when there is a little less than a 1/4 of a tank still in it. The passenger side level sender doesn't 'seem' to send the proper signal.
I have a spare sender for both sides one so before I put the spare one in, I checked the ohm's reading while it was not in the car and it gave good readings on empty and full. I also made sure the float moved up and down freely up/down the sender. However, I'm not sure what readings I should be getting when full and empty.
I put it in anyway, checked the gauge and I get the exact same readings...WTF
So I snipped a new wire and bridged the 2 connections of the passenger side level sender and again checked the gauge and its showing a little less than a 1/4 tank which is what I expected.
My questions are....
1. Are both my level senders gone?
2. Could I replace the Nichrome wires myself?
Or is the voltage supplied to the senders not enough to give the gauge the correct signal, if so, what should the voltage be going into the sender and then out at the other end?
Oh, I've swapped my cluster too and it has no effect.
If anyone can give me any resistance readings I should be expecting from a FULL & EMPTY fuel level sender?
thanks in advance
Barry
