Dashboard gauges
Posted: Tue Jun 14, 2011 9:30 pm
by ScottEgg
Just started up my car and the gauges, bar the speedo, has packed up - no temp, no fuel, no revs. The revs do register for a couple of secOnds then dies. Any ideas chaps?
Re: Dashboard gauges
Posted: Wed Jun 15, 2011 8:15 am
by djsimmy
batterys in the clocks?
my rev counter and temp guage have died so ive got some new batterys gonna fit them later
Posted: Wed Jun 15, 2011 1:39 pm
by ScottEgg
?!?! Don't think a battery should have anything to do with the rev counter?
Posted: Wed Jun 15, 2011 2:04 pm
by m8782538
nut behind the cluster (earth i think) probably not tight enough, been advised about this since my temp guage doesn't work anymore.
Posted: Wed Jun 15, 2011 2:26 pm
by BAZE30
There is a couple of reasons:
1. the battery djsimmy is on about are the ones inside the gauge itself on the SI Board.
2. a fuse has blown. Check fuse 10 and 21.
3. there is a reverse wire under the gear gator, lift this up and check that it hasn't split and is grounding of the chassis. If so, you'll need to get this fixed, temporaily put wire insulation around it.
4. The SI board is Kaput.
Hope that helps
Posted: Wed Jun 15, 2011 7:12 pm
by ScottEgg
Found it! Dodgy switch, just need to source another or rebuild it- how? Cheers
Posted: Wed Jun 15, 2011 7:14 pm
by ScottEgg
Sorry wrong topic! 'twas a dodgy fuse, will wait to see if it goes again
Posted: Wed Jun 15, 2011 10:54 pm
by grantorino
It went because the wiring thru the rubber shift gator is touching the cars metal. This wiring passes under the car to the right side of the transmission to the reverse lights switch screwed into the side of the trans. The wiring should be secured in clips but usually is not if the transmission have ever been removed. it wont blow again till you use reverse and the wiring is just in the right spot.
Posted: Thu Jun 16, 2011 8:20 am
by ScottEgg
cheers grantorino, will check it out.
Posted: Thu Jun 16, 2011 9:48 am
by daimlerman
Cable ties are your friend here!
