320I DIFF RATIO
Posted: Thu Jun 02, 2011 1:30 am
by E30SPORTMAD
can anyone tell me what the ratio is for "87 320i standard open diff? thanks
Re: 320I DIFF RATIO
Posted: Thu Jun 02, 2011 7:50 am
by torquey
3.64 upto 9th/1987 after 9th/1987, 4.10
Re: 320I DIFF RATIO
Posted: Thu Jun 02, 2011 8:54 am
by clarko74
torquey wrote:3.64 upto 9th/1987 after 9th/1987, 4.10
Not quite.
320i 9/85 to 9/87 came with either 3.64 or 3.91. My late 86 320i had a 3.91.
http://www.e30zone.net/e30zonewiki/inde ... ferentials
Re: 320I DIFF RATIO
Posted: Thu Jun 02, 2011 11:34 pm
by E30SPORTMAD
Thanks guys i must find out the exact month and year of the car so it mite make it easyier to work out the ratio, dont want to strip the mans diff down and then say its not what i want if i can help it,
Re: 320I DIFF RATIO
Posted: Thu Jun 02, 2011 11:36 pm
by Jim320i
Mines a 87 320i, with a 3.64 diff... Found out the other day so looking to upgrade it to a bigger one like the 4.10 or larger
Re: 320I DIFF RATIO
Posted: Fri Jun 03, 2011 12:47 am
by E30SPORTMAD
Jim320i wrote:Mines a 87 320i, with a 3.64 diff... Found out the other day so looking to upgrade it to a bigger one like the 4.10 or larger
is it small case or medium case housing?
Re: 320I DIFF RATIO
Posted: Fri Jun 03, 2011 1:54 am
by daimlerman
E30SPORTMAD wrote:Jim320i wrote:Mines a 87 320i, with a 3.64 diff... Found out the other day so looking to upgrade it to a bigger one like the 4.10 or larger
Jim's is a small case diff mounted behind an autobox,what Jim wants to do(I think)is make his car a bit faster at the traffic light GP,so he's looking for a small case 4:1 or possibly a 4:27.
Re: 320I DIFF RATIO
Posted: Fri Jun 03, 2011 8:57 am
by Jim320i
Thanks Malc.
Small like Malc said pal. But its on an auto, also like Malc said.
Re: 320I DIFF RATIO
Posted: Fri Jun 03, 2011 11:04 am
by clarko74
Mine was manual and small case.
Re: 320I DIFF RATIO
Posted: Fri Jun 03, 2011 12:35 pm
by daimlerman
clarko74 wrote:Mine was manual and small case.
Now if you were to want a slightly taller 3.64,and Jim would settle for a slightly shorter 3.91,all you have to settle is the difference between Leicester and Kent....
Re: 320I DIFF RATIO
Posted: Fri Jun 03, 2011 12:37 pm
by 320Touring
Jim320i wrote:
Thanks Malc.
I think m40 tourings (auto) had something like a 4.45
Re: 320I DIFF RATIO
Posted: Fri Jun 03, 2011 1:00 pm
by clarko74
daimlerman wrote:clarko74 wrote:Mine was manual and small case.
Note that I said 'was' in my post. I changed it to a 3.64 medium case lsd when I put my 2.5 lump in.
took the 3.91 down the tip in the end, couldn't give it away, tried selling on here, then on ebay (some fella bought it for £5, paid and then never collected it as he wanted a medium case one), then tried to give it away without any takers.
Re: 320I DIFF RATIO
Posted: Mon Jun 06, 2011 12:48 pm
by damageandyy
whats it like with a 3.64 compared to a 3.91, my 3.91 has just blown up so need a new one was thinking of swapped ratios.
Re: 320I DIFF RATIO
Posted: Mon Jun 06, 2011 12:59 pm
by daimlerman
damageandyy wrote:whats it like with a 3.64 compared to a 3.91, my 3.91 has just blown up so need a new one was thinking of swapped ratios.
Which engine do you have?
Chome bumper E30 up to the introduction of the 325i all had small case diffs,325i brought the medium case diff into E30 use.
Small case diffs have 6 bolts holding the rear cover,medium case diffs have 8 bolts here.Medium case diffs are bigger,hold more oil and have bigger bits inside to make them stronger....
3.64 ratio;
73mph at 3000rpm
4.1 ratio
65mph at 3000rpm
(fiqures for manual 'boxes only)
Never tried a 3.91,but it will fall between the above quotes.
