Control arm ball joint replacement
Posted: Tue May 17, 2011 12:52 pm
by GAZZA3354
Hiya, is it possible to remove the front inner and outer balljoints on my 318i. I'm told that i need a press but is there another way using a vice or g clamps, or can i heat the control arm up to remove them?
Re: Control arm ball joint replacement
Posted: Tue May 17, 2011 1:00 pm
by daimlerman
Given that ECP/GSF sell complete wishbones for about £50 a side,I do not attempt to swap balljoints myself.
A press is certainly required,perhaps your local garage may be prepared to help in exchange for a beer token or two if you are determined to save a pound or two?
Posted: Tue May 17, 2011 1:34 pm
by gnrsoul
i just done mine and it took 5 ton to get the moving so a press would be best!!
Posted: Tue May 17, 2011 3:06 pm
by GAZZA3354
Thanks for the advice, i'll go for complete arms.
