switchable auto 325 kickdown not working
Posted: Sat Feb 05, 2005 1:50 pm
by popupstands
I have a switchable auto 325 and the kickdown has never worked since I purchased car, I don't think their is a cable!! as its switchable is this true?I feel its probally electrical problem somewhere
Posted: Sat Feb 05, 2005 11:37 pm
by popupstands
any guys know about autos, and kickdown problems (well no kickdown)
Posted: Sat Feb 05, 2005 11:59 pm
by Guest
I know the mechanical auto has a cable operated kickdown but I'm not sure about the switchable box - maybe it has an electronic one. Search for a wire or cable coming from the button that the accelerator touches when it's fully depressed. Remove the lower portion of dashboard just below the steering wheel and have a good look.
Posted: Mon Feb 07, 2005 6:09 am
by mrLEE30
There is a switch under the accelerator pedal, this is your kickdown switch, you do have to push quite hard to activate it (so assuming that is not the problem!) it is i an electrical contact so check it is not stuck or badly adjusted. (i.e. when on full throttle it should be depressed fully) if not then check the wiring etc. will look at mine to see where it goes.
mr lee
Posted: Thu Feb 10, 2005 12:06 pm
by popupstands
I have replaced switch I think it must be electical
Posted: Sat Feb 12, 2005 8:18 pm
by popupstands
does anyone have wiring details for switchable auto box?
