wireing help
Posted: Sun Feb 06, 2011 8:18 pm
by Mike_e30_325i
hi i am after some help with a few off the wires and relays on a 1989 325i loom.
i need to no what theses 3 relays are
and also on the injector loom plug is
INJECTORS
brown and white- (earth)
red and white- (live)
COOLENT TEMP SENSOR (blue)
Brown and red- (live)
brown and orange- (earth)
TEMP GAUGE (brown)
brown and yellow
also theres brown and pink but not on other side off plug
i also need to no what each wire is on the idle control valve wireing
ICV
green and white-
red and white-
yellow and white-
and the same for the tps sensor
TPS
blue and brown-
brown-
brown and black-
if anyone nos could they fill in the gaps for me please cheers mike.
Re: wireing help
Posted: Sun Feb 06, 2011 8:40 pm
by Brianmoooore
White is DME (main engine) relay
Orange relays are fuel pump and lambda sensor heater. Fuel is the one with a green/purple wire going to pin 87.
Spare wire in injector loom is a left over from when E30s had two pin brown temp. sensors. The same wire that's present on pin 20 of the engine loom socket on some cars that causes a burn up when a later engine loom is fitted.
ICV: red/white is 12 volts + from the DME relay, other two are the signal wires for the balanced armature design.
TPS: brown is earth, brown/blue is idle, brown/black is WOT.
Re: wireing help
Posted: Sun Feb 06, 2011 8:45 pm
by Mike_e30_325i
cheers for the quick replay
