help
Posted: Wed Jan 26, 2011 8:58 pm
by clig
325i cabby engine sputtering ,missing ,losing power when i am driving,also when stationary the gearbox makes a random clanking noise .when i push clutch in noise goes, any ideas what i wrong ?????
Re: help
Posted: Wed Jan 26, 2011 11:10 pm
by Brianmoooore
Engine problem is most likely an air leak on the inlet side.
Gearbox problem is 'normal'.
Post in the correct forum please!
Re: help
Posted: Thu Jan 27, 2011 10:14 am
by clig
thanks Brian will check it out. and will do in future
Re: help
Posted: Thu Jan 27, 2011 6:01 pm
by clig
sorted.turned out it was fuel line had slit split in it.
Re: help
Posted: Thu Jan 27, 2011 6:11 pm
by Brianmoooore
If a fuel line was split enough to affect engine performance, you are very lucky you haven't incinerated the whole thing!
Re: help
Posted: Fri Jan 28, 2011 10:10 am
by clig
that's what I was thinking. check air boot that was fine all other plugs and leads were ok. fuel line had a small split in it were it's connected to injector rail. luck or what.
