Intermittent miss fire/loss of power??
Posted: Mon Oct 25, 2010 9:31 pm
by 320stu
My 1990 320i se seems to have developed an intermittent miss fire/loss of power? Its happend to the wife a few times and once with me.
I was driving for about 5 mins at around 45mph and felt sort of a loss of power, I pulled over put the car in netural and it was miss firing and the engine was hunting on idle after reving it? Everytime I tryed to pull away it had no power and nearly stalled, after about 2/3 min of reving from idle to about 4k and letting it idle then giving it a nother rev etc etc it was fine, I then carried on driving for another 20 mins and it never done it again? In total its done it about 5/6 times.
Any idea's guys??
Re: Intermittent miss fire/loss of power??
Posted: Tue Oct 26, 2010 9:52 am
by 320stu
anyone??
Posted: Tue Oct 26, 2010 10:00 am
by Ziggy
Fuel pump?
Posted: Tue Oct 26, 2010 10:15 am
by Silverfang
Could be the ICV sticking, I've had a similar issue and it turned out to be the ICV (idle control valve) sticking and causing the engine to overfuel.
Posted: Tue Oct 26, 2010 10:39 am
by town325i
I would check the wiring under the inlet manifold on the engine loom side to see what the wires are like as this causes all sorts of trouble.
Posted: Wed Oct 27, 2010 12:06 am
by 320stu
Silverfang wrote:Could be the ICV sticking, I've had a similar issue and it turned out to be the ICV (idle control valve) sticking and causing the engine to overfuel.
Is this what the air box bolts onto? how can I stop it sticking? (if that is the problem!)
Posted: Sun Oct 31, 2010 12:27 am
by 320stu
anyone?
Posted: Sun Oct 31, 2010 12:31 am
by pac1982
Ziggy wrote:Fuel pump?
2nd that
by E30BeemerLad
No the air box is bolted to the air flow meter.
I'd recommend checking the wiring plug under the inlet manifold as suggested above, also worth checking wiring to things like crank sensor to check they look in order and haven't been caught by the belts etc.
Fuel pump is another suspect. Next time it does it, lift the rear seat base and give the inspection cover on the driver side a thump and see if the problem goes away.
Posted: Mon Nov 01, 2010 4:14 am
by stackede30
I had this problem aswell and it was my ICV. I cleaned mines up and it worked for alil then the problem came back. Bought a new one and now it runs fine.
Posted: Mon Nov 01, 2010 11:11 am
by Ajsingh
I had this issue and found a very small split in one the h/t leads.... Replaced the lead, was all good.. Get water in a bottle n spray it over the dizzy cap and all the h/t leads whilst giving a bit of rev and u might b able to see a small spark seeping out of somewhere (obv dnt use shit loads of water)
