Hi
Forgive me if this has already been answered on this forum.
Can a 13 button OBC be installed into any e30? I have a 316i '91
Also, are the overhead checklights part of the 13 button OBC, if not can these also be installed too?
cheers
13 Button OBC and Overhead check lights
The obc needs the correct chip for a 4 pot.
The overhead check control is separate, not sure what's involved
Current E30 325i, E63 630is.
Morat
The overhead check lights are separate to the OBC, but not many people seem to bother retrofitting them.
- rmurphy520
Ok so if I was to buy the whole kit with all the trimmings it can be done?
- rmurphy520
Happy days. cheers mate. Is it much work?
- rmurphy520
Sorry mate if this is dumb. What does that mean? (4 pot?)
- Brianmoooore
OBC is a simple retrofit.
Overhead check panel requires the whole of the main car wiring loom to be changed, from the front RH corner of the car to the back RH corner, all the way back the LH side, plus several branches, including the fusebox. After all that, there is still no provision for an oil level sensor on M40 engines.
- rmurphy520
Thanks for a very detailed description
I will definitely go about the 13 button OBC and maybe the next e30 i buy will have the overhead check lights
