no speedo
Posted: Thu Sep 23, 2010 10:26 am
by pnd
my speedo and mileage counter stopped working this morning rev counter still works though economy gauge just swings from side to side. Any one got a likely diagnosis?
Re: no speedo
Posted: Thu Sep 23, 2010 10:39 am
by Ziggy
The sensor wire where it connects to the diff.
Re: no speedo
Posted: Thu Sep 23, 2010 10:58 am
by pnd
is this most likely or the instrument cluster itself it just went suddenly?
Re: no speedo
Posted: Thu Sep 23, 2010 12:39 pm
by mr_s1ngh0
hi
i had the same problem on my 318is. after checking the clocs, everything seemed fine there. having checked the speed sensor wires, they were completely corroded. i check about to see if i could get another sensor with wires already conencted with no luck. managed to get my uncle who is pretty handy with electrics to solder new wires to the old connectors and it worked straight away.
Re: no speedo
Posted: Thu Sep 23, 2010 12:48 pm
by George_Of_The_Jungle
Ziggy wrote:The sensor wire where it connects to the diff.
+1
My wires corroded, came away from the plug when i checked the connection. Bought a couple of new plugs (90degree female sockets with new wire sticking out) from BMW, cost about £10 if i remember rightly
Re: no speedo
Posted: Thu Sep 23, 2010 3:51 pm
by maxlee
+1
+2
had about 4 e30's do this easy fix and you can check by just jacking up the car a bit and sticking your head under insted of pulling the clocks out :cool:
Re: no speedo
Posted: Fri Sep 24, 2010 2:05 pm
by pnd
cheers will check the sensor first.
