(Kangarooing ?) @ 1500rpm
Posted: Sat Sep 18, 2010 8:29 am
by teatime39
1990 320i cabby just does not like driving at 1500rpm ,it kangaroos every time. I've checked for air leaks with WD all ok .
its had a new dizzy and arm and plugs , I'm gonna do an oil change today with Castrol 10/40 is there anything else i should do to stop it doing this , Thanks
Re: (Kangarooing ?) @ 1500rpm
Posted: Sat Sep 18, 2010 9:15 am
by eddieg
Airflow meter - not sure of design in this case?
Posted: Sun Sep 19, 2010 12:33 pm
by Adil786
Does this happen just at that rev range in a particuar gear, or all gears?
Posted: Sun Sep 19, 2010 2:40 pm
by m_jermyn
I have read a few posts like this and they usually end up being fuel pressure regulator
Posted: Sun Sep 19, 2010 4:10 pm
by Brianmoooore
Make sure the throttle position switch is correctly adjusted, but if this is OK, the basic cause is a weak mixture. This can be for many reasons, including air leaks, worn bores/rings, AFM, injectors, fuel pressure regulator, etc.
Posted: Thu Sep 23, 2010 10:55 pm
by KimH
My kangarooing at minimal throttle openings - like crawling along in motorway jams - turned out to be caused by the Blue Temp Sensor.
A good cheap place to start and, if it doesn't fix the problem, at least you'll have a spare sensor.
Posted: Fri Sep 24, 2010 1:48 pm
by andy523
where is this sensor located ?
Posted: Sat Sep 25, 2010 9:44 am
by Brianmoooore
andy523 wrote:where is this sensor located ?
Right at the top of the engine at the front, on the water outlet elbow.
Posted: Sat Sep 25, 2010 11:57 am
by markus_74
mine is like your but after adjusted the TPS and replace a few times with different afm then I can crawl with 1200 rpm with 2 or 3rd gear
