Anyone know what this connector might be for?
Posted: Mon Sep 13, 2010 2:36 pm
by shonky
And why it has been cut with a fuse connection?
Also what reason the fuse may have been removed?
I kinda want to remove the fuse and wire it back up as normal
Re: Anyone know what this connector might be for?
Posted: Mon Sep 13, 2010 4:01 pm
by pac1982
My guess is its part of an old alarm/immobilizer system seeing as its located where it is.
If you not very good with wiring or car electrics I would leave it well alone as it may cause more problems if you try to get rid of it.
If you are fairly confident then go ahead and get rid its defiantly not OE
Posted: Mon Sep 13, 2010 8:34 pm
by shonky
pac1982 wrote:My guess is its part of an old alarm/immobilizer system seeing as its located where it is.
I was kinda hoping someone would have told me what that part of the loom was for before I chopped the fuse part out and reconnected......So I would know what to look out for when it was gone!
