E36 rack swap, are E30 tie rods needed?
Posted: Fri Aug 27, 2010 1:24 pm
by E30BeemerLad
When I swapped the E36 rack into my chromie I just bolted the job lot up complete with the E36 inner & outer tie rods.
No dramas with fitting etc.
I've heard a few mention that they fitted the E30 inner & outer tie rods to the E36 rack. Is this actually necessary?
Lee
Re: E36 rack swap, are E30 tie rods needed?
Posted: Fri Aug 27, 2010 1:41 pm
by Barton
whats the benefit of this? and is it a straight swap?
my rack may need replacing as i'm getting some strange noises from the steering
Posted: Fri Aug 27, 2010 4:08 pm
by kilrone
you can use either i used the e36 stuff for the sake of stating with newer parts
Posted: Fri Aug 27, 2010 4:11 pm
by Cook318IS
as kilrone said you can use the e36 ones. im using the e36 ones becuase the ones on the rack were ok :)
Posted: Fri Aug 27, 2010 9:09 pm
by DanThe
I just fit new track rod ends, E36 obviously
Posted: Mon Sep 13, 2010 7:49 pm
by StuBeeDoo
DanThe wrote:I just fit new track rod ends, E36 obviously
I used E30 TREs when I did mine.
Posted: Mon Sep 13, 2010 10:48 pm
by BadDave
I used New E30 ones as the ones that came attached to the E36 rack were of unknown age/condition
Posted: Mon Sep 13, 2010 11:34 pm
by Barton
how easy is the swap? i presume there's a guide?
