Spark Plugs for M20
Posted: Fri Aug 27, 2010 12:37 pm
by Jack-J
Hi all,
I have a BMW E30 320i and has started doing a bit of drifting. What are the best spark plugs for this engine?
Regards
Jack
Re: Spark Plugs for M20
Posted: Fri Aug 27, 2010 5:29 pm
by town325i
ngk's are the best plugs you can use these engines dont run right on the fancy multi electrode plugs
Posted: Fri Aug 27, 2010 5:42 pm
by silversideofthemoon
ngk in mine all me local garage sells
Posted: Fri Aug 27, 2010 6:16 pm
by HJG-E30
Guy before me put some fancy 4 point Bosch ones in. If I replace these with NGK will i see a noticable difference in performance?
Posted: Fri Aug 27, 2010 8:15 pm
unsure i always used champion as it was stated somewhere i read ....just use ngk now and there bout 2 quid of mme mate in his place each
Posted: Fri Aug 27, 2010 9:21 pm
by town325i
HJG-E30 wrote:Guy before me put some fancy 4 point Bosch ones in. If I replace these with NGK will i see a noticable difference in performance?
You will notice a difference ove those things i used a set for a few months in my 325i and i had all sorts of problems cause by those plugs.
Switched back to the ngk's and the car ran fine
Posted: Fri Aug 27, 2010 9:25 pm
by e30topless
NGK BPR6ES , the best M20 plugs
