Handbrake problem - rolls forward/back a few inch when on?
Posted: Thu Aug 19, 2010 10:13 pm
by e30gazza
When i apply the handbrake on my touring, the car rolls back or forward a couple of inches ! almost like putting an auto in `park` and not applying the handbrake.
Any ideas please?
Gary.
Re: What is this likely to be?
Posted: Thu Aug 19, 2010 10:26 pm
by e30gazza
no offers of your superior intellect?
I only need telling once, - honest !
Gaz.
Posted: Thu Aug 19, 2010 10:39 pm
by Charlie3000
hah, mine does this too, I just ignored it
Posted: Thu Aug 19, 2010 10:44 pm
by e30gazza
Haha ! I wish i could ! OCD is not easy to live with !
Posted: Thu Aug 19, 2010 10:49 pm
by Charlie3000
Just out of interest, does yours make a clunk if you give the handbrake a quick yank after you've set off? Mine does, and that is really starting to irritate me!
Posted: Thu Aug 19, 2010 10:51 pm
by e30gazza
No, mine doesn`t do that bit !
by TouringTash
I always leave mine in gear. too much to risk on a 20 odd year old setup.
Posted: Thu Aug 19, 2010 10:58 pm
by e30gazza
Yes i do, but when i apply handbrake at lights, etc, on a hill if you take your foot off the brake, its like there is a bit of play before the handbrake stops the car.
Posted: Thu Aug 19, 2010 11:03 pm
by skipunda
I wonder if the handbrake is slightly loose inside the disc.
Edited your title by the way, feel free to amend it by editing first post.
Posted: Fri Aug 20, 2010 4:18 pm
by e30gazza
No problem Skip. Thanks for the info, will investigate in the morning.
Posted: Fri Aug 20, 2010 4:25 pm
by skipunda
It's not
inside the disc, that doesn't make any sense. It's, you know, around there. What is known is that it solved the same issue on one of mine.
see what happens when they leave me on my own
Posted: Fri Aug 20, 2010 4:26 pm
by pnd
most need new cables by now.
by TouringTash
you got that pic up far to fast skip.
Keep a library of them to hand
Posted: Fri Aug 20, 2010 8:49 pm
by DHFiS
Even if you have rear discs the hand brake uses drums and shoes. Pulling the brake handle brings the shoes up to the drum but to fully engage them the car moves slightly and pulls the two together.
Its normal AFAIK for there to be a small movement of the vehicle.
Posted: Fri Aug 20, 2010 10:08 pm
by Ilkorin
Unfortunately this could be due to a number of reasons. When were the handbrake shoes last changed? If they are reasonably old, they may need adjusting if you want them to hold firmly. Also the backplate tends to rust where the pins that hold the shoes go in, which can create a bit of slop.
The short answer is that you might want to have the handbrake assembly apart and see what's what. It's quite an easy job and you might find the problem is solved with a quick turn of the adjuster.
Posted: Sun Aug 22, 2010 4:18 pm
by e30gazza
Right, i had a good look today. I`d bought a new set of shoes, but tbh it didn`t need them. Ihad the discs off and cleaned them up, tightened the handbrake adjuster nuts. Now it holds great!
- But ! I held the disc firmly, and it still moved from side to side, probably an inch, and there was a slight knocking from under the centre of the car. Could it be a prop joint worn? driveshaft,diff,etc?
Thanks.
Posted: Sun Aug 22, 2010 9:23 pm
by e30gazza
Still no answers folks?
