suspension
Posted: Thu Jul 22, 2010 6:29 pm
by aceifty
hi does anyone now what size the front struts are on a 1989 320i cab.
Re: suspension
Posted: Thu Jul 22, 2010 9:35 pm
by riklusby
i'm pretty sure all 6cyl had 51mm struts
Re: suspension
Posted: Thu Jul 22, 2010 9:37 pm
by Barx325i
no, the 320's didn't - cab's, tourers, iS's & 2.5's possibly early 323's all do - with the exeption of 4 pot cabs/tourings
Re: suspension
Posted: Fri Jul 23, 2010 12:01 pm
by ImysE30
It should have 51mm struts. All cabby's as well as touring's have 51mm struts and rear disc brakes regardless of engine size.
Re: suspension
Posted: Fri Jul 23, 2010 2:59 pm
by Barx325i
that clears that up then..
Cabs, Tourings, 325's iS's and poss 323's
I'm winning against the loom Imys
Re: suspension
Posted: Fri Jul 23, 2010 3:02 pm
by ImysE30
That's factory spec, could have anything on it now after 15 years
Best bet is to measure up what's fitted now.
Re: suspension
Posted: Fri Jul 23, 2010 3:06 pm
by Rav335uk
All cabs have the larger 51mm struts.
Re: suspension
Posted: Fri Jul 23, 2010 3:08 pm
by Barx325i
I've not dabbled with m40 cabs/tourings
Re: suspension
by ImysE30
As stated above already
Re: suspension
Posted: Fri Jul 23, 2010 3:20 pm
by Rav335uk
ImysE30 wrote:As stated above already
That was for Barclay
Re: suspension
Posted: Fri Jul 23, 2010 4:18 pm
by Barx325i
think your sig needs updating Rav
....the bottom bit, I'm not dissing your quote, although it has been on for a while
Re: suspension
Posted: Fri Jul 23, 2010 9:45 pm
by Rav335uk
Done mate
Re: suspension
Posted: Sat Jul 24, 2010 9:30 am
by kevyd
Quick question,any advantage having the 51mm struts? as i have a320i which has the smaller struts,looking to refurb the suspension over the winter so wondering whether to get these before i start.
Re: suspension
Posted: Tue Jul 27, 2010 7:37 pm
by Rav335uk
More range of shocks, Bilstiens B12's, B8's and B6's, and a choice of springs too
Re: suspension
Posted: Tue Jul 27, 2010 9:02 pm
by Barx325i
+ do the job a little better then wobbly 45's
