S14 no revs and cuts out.
Posted: Sat Jun 19, 2010 1:50 pm
by pony2
This has been an intermittent problem for a while now. It does not seem to matter if the car has been running a while or it is cold.
Basically whist driving the revs completely drop off and the engine sputters. Usually if the car is switched off for five or ten minuets it returns to normal. Today the car really didn't want to start again and sounded terrible when turning over. After about 50 minuets hey presto back to normal, revs restored and running fine.
I have recently fitted a new dizzy cap and rotor arm - ran fine after fitting. Could it be the fuel relay?
http://www.c3bmw.co.uk/StockItem.asp?ca ... m=unassign
http://www.realoem.com/bmw/showparts.do ... g=12&fg=35
Re: S14 no revs and cuts out.
Posted: Sat Jun 19, 2010 2:03 pm
by baptie0
can you hear the fuel pump pulsing when you try and restart the engine?
Posted: Sat Jun 19, 2010 2:11 pm
by pony2
baptie0 wrote:can you hear the fuel pump pulsing when you try and restart the engine?
Can't say I can either when it is running without revs or back when it is back to normal.
A new fuel pump and filter have been fitted.
Posted: Sat Jun 19, 2010 2:18 pm
by weed1
Could be an overheating fuel pump relay.
Could be an out of spec engine speed sensor.
Could be a problem in the DME.
m
Re:
Posted: Sat Jun 19, 2010 3:06 pm
by pony2
I know it is difficult to diagnose. Forgive my ignorance, where is the fuel pump relay?
