front crossmember are all e30s the same
Posted: Mon May 10, 2010 6:07 pm
by TOMMYSPANNER
hi! was wondering if the e30 325i front crossmember/subframe was a common part, even with cars having the less powerful,l 4 cylinder configurations,regards tommy.also,any easy way to fit the later diagonal outlet radiator to a 1987 prefacelift model tech 1?
Re: front crossmember are all e30s the same
Posted: Mon May 10, 2010 6:14 pm
by DanThe
They are all the same
To fit the later radiator you need the mount brackets which do not come on prefacelifts
