Driver's electric window won't close
Posted: Sat May 01, 2010 1:32 pm
by mash
Winds down, but not back up.
Any ideas before it starts raining.
Can you crank it back up manualy using the hex key in the toolbox - or is that just for the sunroof?
Thanks in advance
Re: Driver's electric window won't close
Posted: Sat May 01, 2010 1:51 pm
by Brianmoooore
If it makes no attempt to move up, it's the switch that's the problem. Swap it for one of the others for a quick fix, then open up the switch and clean/lubricate it.
It's very rare to find one that is actually broken and unrepairable.
Posted: Sat May 01, 2010 1:53 pm
by mash
Thanks Brian, thanks worked
You are a star!!!
Posted: Sat May 01, 2010 1:57 pm
by cbv8
Take the offending switch out prise the thing apart carefully then dismanlte watch you dont drop the little springs and things 8O Clean all the brass contacts with some fine wet&dry spray with a little WD-40 then reassemble worked for me good luck :wink: OOPS :o: i just noticed Brian beat me to it :roll:
