M-Tech2 SideSkirt Clips.
Posted: Mon Apr 05, 2010 12:02 am
by Security2U
Lads see number 5 in the link below the clamps that snap on to the sideskirts to hold them on to the car.
Do i need to drill holes on to the car to get these clamps to fit.?.
http://www.realoem.com/bmw/showparts.do ... g=51&fg=20
Re: M-Tech2 SideSkirt Clips.
Posted: Mon Apr 05, 2010 12:14 am
by Topblag
can't get the link to work ?
Posted: Mon Apr 05, 2010 1:18 am
by Security2U
Link is now working.
Posted: Mon Apr 05, 2010 2:12 am
by snakebrain
I'm pretty sure you do. I was going over the installation for the e28 one today and you have to drill for it. You also have to get the diameters exactly right or it'll all go a bit pete tong. You drill 8mm holes then open them to 9mm with a hand drill...
Here's the E28 one. I imagine it'll be more or less the same idea. :)
http://www.ow.no/archive/eba/890.PDF
Ooops, just looked at the link. I thought you were talking about the clips along the length of the sill. I think you maybe drill for that one too. It's all in the guide anyway..
Posted: Mon Apr 05, 2010 9:59 am
by charlE30
I've just removed a full tech 2 kit and can't work out what one number 5 is?? The side pods all fit using the holes from the original bumpstrips, it's bracket number 20 that need holes drilling. There are 16 of these brackets each needing 2 holes drilling.
I have a feeling these are why you can buy a drilling template from bmw to fit the kit.
Posted: Mon Apr 05, 2010 11:44 am
by Security2U
charlE30 wrote:I've just removed a full tech 2 kit and can't work out what one number 5 is?? The side pods all fit using the holes from the original bumpstrips, it's bracket number 20 that need holes drilling. There are 16 of these brackets each needing 2 holes drilling.
Number 21 is the clamps that hold the bottom of the sideskirt to the underneath of the car,Now number 5 is what holds the sideskirt tight to the body when you pull back the sideskirt it snaps away from the number 5 clip in the link.
All these fecking clips would drive you mad. :x
Posted: Mon Apr 05, 2010 5:04 pm
by charlE30
There are also 16 of the number 20 that clip the lower skirt tight to the actual sill aswell just below where the doors shut. If need be I can go and take photo's of the holes and the clips I removed.
Do you have any of the number 20 clip for your kit?
I'm going to be fitting more door tech 2 in the near furture and I'm not looking forward to it, did you get the drilling template from BMW?
Posted: Mon Apr 05, 2010 5:06 pm
by 320ise
when i did this on my is i just took my time and measured and marked it up and it looked factory in the end! took me a full day though!
Posted: Mon Apr 05, 2010 7:03 pm
by Security2U
charlE30 wrote:There are also 16 of the number 20 that clip the lower skirt tight to the actual sill aswell just below where the doors shut. If need be I can go and take photo's of the holes and the clips I removed.
I want to fit a Tech2 kit to my E30 so i just pulled back my sideskirts on my sport and thay have the clips there fitted im just going to get all the clips and bits i need and go in to BMW some other day done the line.
