fire extinguisher Q
Cloggy Saint
Cloggy Saint
- Brianmoooore
I tried one a while back, and it worked fine!
Cloggy Saint
- Brianmoooore
Stops when you release the handle.
Cloggy Saint
My Dad runs a fire extinguisher company, i wouldnt test it I was always told
(depending on the sort) over time it can loose its pressure. This is because the original 'seal' has been broken. Extinguishers were designed to work once not to be used a little then to seal 100% again.
I was thinking of offering a group buy for extinguishers on here, if you have any queries im sure i can help.
- Brianmoooore
I'm well aware of that. The extinguisher wasn't one I was going to use for any serious purpose.
he30
- Contact:
There fixed with small screws with a 10mm hex bolt head i think and screw straight into the seat? essentialy selp tap indatourer wrote:And of course the next question is how can I best attach it to the seat?! Obviously it's the 2 holes at the front and 2 at each end but there's no way of getting a nut on any bolt that I use. Am I missing some sort of fancy fixings?
Cloggy Saint
