Bleedin(g) brakes - Seized bleed valve
Posted: Sat Mar 06, 2010 7:09 pm
by fieldl
Went to replace the brake fluid today only problem faced was the fact that the rear offside valve has seized solid typical first one to do too. Trying to free it off just led to it getting less and less nut shaped. So I will order a replacement (maybe two) just in case.
Just to check, what happens when I remove the valve? Anything in particular I need to be aware of?
I presume it just unscrews eventually.
Re: Bleedin(g) brakes - Seized bleed valve
Posted: Sat Mar 06, 2010 7:20 pm
by fieldl
Oh and another question anyone know what colour RBF600 is supposed to be?
Posted: Sat Mar 06, 2010 7:32 pm
by fieldl
34111153197 thats the part number
For my reference so I can order the parts ;)
Posted: Sat Mar 06, 2010 7:48 pm
by Daf318is
Just be carefull - I've snapped one off in the past and then you're in trouble!
I ended up drilling it out with a much bigger hole, fitting a stud to the new "big hole" tapping that and re-fitting a new bleed screw!
I could've bought a S/H caliper.. but that would've been too easy
Soak it in WD40 for 24hours before you try and shift it again - perhaps a little bit of heat to free it
Posted: Sat Mar 06, 2010 8:14 pm
by DanThe
Blowtorch it before you start trying to unscrew the thing, bleed screws are now £5 from the skanking dealers
Good job I have a wire wheel to clean the old ones up
Posted: Sun Mar 07, 2010 1:51 pm
by Daf318is
DanThe wrote:Blowtorch it before you start trying to unscrew the thing, bleed screws are now £5 from the skanking dealers
Five quid? It's only a ruddy bolt with a hole in it really!
Posted: Sun Mar 07, 2010 8:01 pm
by fieldl
£5 is a bit of a mickey take isn't it! oh well.
They are soaking in WD40 so will have a crack at them next weekend and see how it goes.
Thanks all
Posted: Sun Mar 07, 2010 8:18 pm
by Daf318is
fieldl wrote:£5 is a bit of a mickey take isn't it! oh well.
Thanks all
Keep giving them a daily squirt of WD 'till next weekend - that should free them up a bit
Posted: Mon Mar 08, 2010 4:17 pm
by fieldl
£5.10 for a valve
Will have it tomorrow
