E30 m40 318i engine service
Posted: Thu Mar 04, 2010 10:03 pm
by bmbartlett
What's involved in cleaning the oil spray bar on my 318i m40 1989 engine and also what exact oil would best suit as it's a bit tappety? I keep getting chucked between 5w-40 and 10w-40.
Another quick question, is there any way of repairing split hoses?
Re: E30 m40 318i engine service
Posted: Thu Mar 04, 2010 10:09 pm
by kam-325i
Cleaning the spray bar:
I soak mine for a few hours in white spirits/turps to release any gunk.
Split hose:
depends where the split is and how big the hose is.
Posted: Thu Mar 04, 2010 10:12 pm
by bimanut
Most people just change the spray bar as they arent that easy to clean.
Although i had a spare one and soaked it in petrol for a week and blew it out with an air line.
If your engine is abit tappety then drop some deisel oil in for a couple of thousand miles and it will help clean every thing and quieten it down a bit.
Hoses arent something that can realy be repaired.Youl just have to suck it up and get another one
Posted: Thu Mar 04, 2010 10:28 pm
by bmbartlett
Is the oil spray bar easy to see and remove once you take the cover off?
Posted: Thu Mar 04, 2010 11:37 pm
by Messenjah
as for repairing a split hose if its a low pressure hose funds are that tight and you dont mind it looking a bit shit ... get some damp proof course instans gasket cable ties and duct tape ..
spred the ig over the dpc wrap it round cable tie in place then round and round with duct tape ...
tbh this is an emergency get you home repair with things you may have in an emergency toolbag (i do ) and itsnt going to be much cheaper then replacing the hose iespecially with good second hand
what hose is it ive probably got one
Posted: Fri Mar 05, 2010 8:04 pm
by bmbartlett
http://www.realoem.com/bmw/showparts.do ... g=13&fg=15
hose number 10
also i took hose 3 off in that diagram tonight and it was far from shiny inside were it goes into the engine, a thin black tar like stuff, bit like dried oil, any idea what that is about and do you think a taking it all apart and give a good clean up with help with my jerking in traffic? thanks for any help
Posted: Fri Mar 05, 2010 8:11 pm
by dobbie82
I am sure a spray bar was only a tenner or so when I lived in the Lakes (4ish years ago) but now seems to be £37 quoted in the genuine parts section?
People used to change them as easier than cleaning it but for that price get your rubber gloves and petrol/parrafin and clean it
