Knocking when turning
Posted: Fri Feb 26, 2010 11:25 pm
by oli-b
My 320i has just started to make a loud knocking/rubbing noise from the front when turning. It started off just when turning left but now happens all the time. Can't see the tyre hitting anything. Any ideas? [/list]
Re: Knocking when turning
Posted: Sat Feb 27, 2010 11:25 am
by Boyraceruk
It was the bush in the lollipop on mine. Replaced it, fine now.
Posted: Sat Feb 27, 2010 11:41 am
by fuzzy
a balljoint or wheel bearing would be most likely.
Posted: Tue Mar 02, 2010 7:41 am
by craigd
was the ball joint on mine, replaced the whole wishbone as it was easier
Posted: Tue Mar 02, 2010 6:13 pm
by richy187
I have the same problem
so far i've replaced the steering rack, shocks and springs (these needed doing any way), ARB bushes, drop links(twice don't buy them for £8 off ebay) and lollipop bushes. next on the list is track rod ends if they don't cure it then I'll be getting new wishbones as well.
