318 is throttle body electrics
Posted: Mon Dec 28, 2009 6:22 pm
by LeonNewton
wot are the electrical connections for on my throttle body. wot signals do thay send or receive and haw dose the throttle body generate the signal?
Re: 318 is throttle body electrics
Posted: Mon Dec 28, 2009 6:31 pm
by DHFiS
Throttle position switch - measures now open the butterfly is. Its a variable resistor so the resistance rises and falls as the butterfly opens and closes.
Posted: Mon Dec 28, 2009 6:42 pm
by LeonNewton
is that the only signal? also dose it just measure it on the big butterfly or throttle cable or dose it measure both butterfly valves independently? (if that makes sense)
Posted: Mon Dec 28, 2009 6:48 pm
by DHFiS
Look on this link to realOEM for part no 2. This is the TPS.
http://www.realoem.com/bmw/showparts.do ... g=13&fg=15
Posted: Mon Dec 28, 2009 6:58 pm
by LeonNewton
thanks. so thats it.
any chance anyone knows the max and min resistance the TPS creates allowing the ECU to determine wether the throttle is for fully open and fully closed?
Posted: Mon Dec 28, 2009 9:07 pm
by DHFiS
Copied this from realOEM
02 THROTTLE VALVE SWITCH 4 KOHM
If that is correct the range will be from about 0 to 4000 ohms but I have never tested one on the car.
Posted: Mon Dec 28, 2009 9:25 pm
by LeonNewton
ok. think that all makes sense. tar for your help.
