Spark plugs M20
Posted: Sun Nov 22, 2009 1:09 am
by mrcool
I have searched on here and found some people recommending the OEM Bosch plug and others saying NGK.
Here is what real oem shows for my 320...non cat.
A bit confusing....
Re: Spark plugs M20
Posted: Sun Nov 22, 2009 7:11 am
by shedrool83
As above :D
Re: Spark plugs M20
Posted: Sun Nov 22, 2009 7:19 am
by B7
^^^^^^^^^^^ what they've said. It's been proven over time that the NGK suits the M20 best.
Re: Spark plugs M20
Posted: Sun Nov 22, 2009 10:07 am
by bpowell555
Is there any difference between NGK plugs for high and low compression 2.5s?
http://www.gsparkplug.com/products/spark_plug/ngk/zgr5a
vs BPR6E / BPR6EIX (iridium)
Re: Spark plugs M20
Posted: Mon Nov 23, 2009 1:15 am
by jay528ise1985
ZGR5A are meant for later (approx '87 on) 320 & 325 and have a projected nose so the spark is placed further into the air/fuel mixture, apparently increasing efficiency and having the added benefit that the tip is cooled by the incoming air/fuel mixture during the induction stroke to a greater degree.
I am using these plugs on my 2.7 27 6E B/731 (many people say they don't work with the high compression of the 2.7 conversions), they remain almost immaculately clean with a pale brown colour and no signs of overheating, glazing or cracking.
To summarise: Superb plugs! (In my opinion/experience)
Re: Spark plugs M20
Posted: Mon Nov 23, 2009 9:54 pm
by mrcool
OK mine is 88 320 and going by the book that is ZGR5A. I see some people swear by the BPR6ES tho...
So...
NGK ZGR5A v BPR6ES
Re: Spark plugs M20
Posted: Mon Nov 23, 2009 10:59 pm
by Simon13
mrcool wrote:OK mine is 88 320 and going by the book that is ZGR5A. I see some people swear by the BPR6ES tho...
So...
BPR6ES
get it?!
Re: Spark plugs M20
Posted: Mon Nov 23, 2009 11:01 pm
by Sanchez
As above BPR6ES
Re: Spark plugs M20
Posted: Tue Nov 24, 2009 8:23 pm
by mrcool
get it?!
Yes ok, in some peoples opion, but when others (& NGK) come along and say..
jay528ise1985 wrote:ZGR5A are meant for later (approx '87 on) 320 & 325 and have a projected nose so the spark is placed further into the air/fuel mixture, apparently increasing efficiency and having the added benefit that the tip is cooled by the incoming air/fuel mixture during the induction stroke to a greater degree.
It contradicts that and makes things more confusing. So are you saying it doesn't matter if its early or late, cat or non-cat. The early plug should be used still ?
Re: Spark plugs M20
Posted: Tue Dec 01, 2009 3:24 am
by jay528ise1985
I wish the ZGR6A was still available, then I could have the best of both worlds!
Re: Spark plugs M20
Posted: Thu Dec 03, 2009 2:05 pm
by BEAMERFNATIC
I have Bosch plugs in my beamer and the car is running sweet at the moment ,they are
WR8LC+ Bosch super plus Yttrium .............
This is not to say that NGK are not good as they are a fantastic plug no doubt about it ,basically these are the first plugs I used and they have been great so I have stuck to them ...
