what should i get to the gallon?
B4UR
Fri Oct 30, 2009 7:16 pm
What should i be getting to the gallon with my 316i touring? And at motorway speeds do others feel the car revs quite high ?
Just curious to see what others get also with the 1.8 , 2.0 and 2.5
ali-vert
Fri Oct 30, 2009 8:02 pm
i got a 318 and i dont get alot!! put 50quid in on sunday, done 200 miles and nearly in the red, bad times
**BANNED**
Fri Oct 30, 2009 8:06 pm
We ran a 316i touring for several years.
It's best tank to tank fiqure was 38mpg...worst was 18mpg...
In general use I reckoned on 31-33mpg.
I fitted a 4.1 diff to replace the 4.45,did bugger all for fuel economy but made it a whole lot quieter on the motorway!
Youth is wasted on the young.
sihooker
Fri Oct 30, 2009 8:10 pm
ali-vert wrote:i got a 318 and i dont get alot!! put 50quid in on sunday, done 200 miles and nearly in the red, bad times
The muscles in your right leg must be massive! You do realise that there's a 5th gear..?
I get 33mpg average in my 318i.
e301988325i
Fri Oct 30, 2009 8:14 pm
I get 22ish mpg on lpg in my 325i
I said:
e30topless said:
lock the wife in there
ProToZyKo
Fri Oct 30, 2009 8:35 pm
My 320i automatic get around 30-33 mpg. Would love to get above 38.
Think i can drive 45 on a full tank.
Not motorway driving, country roads up and down, turning left and right. 5-15 min drives.
B4UR
Fri Oct 30, 2009 10:00 pm
so when i work out im getting 35 on a run its around about average. How hard is it to change the diff on these cars and will it go into the casing already there?
ali-vert
Fri Oct 30, 2009 10:04 pm
probably is due to my driving style to be honest! and hardly do any motorway driving so i probably dont count lol
**BANNED**
Fri Oct 30, 2009 10:11 pm
B4UR wrote:so when i work out im getting 35 on a run its around about average. How hard is it to change the diff on these cars and will it go into the casing already there?
You swap the casing!
Support the car securely so that the wheels are free .
Unbolt the driveshafts at the diff output flanges.
Unbolt the propshaft from the font of the diff.
Support the diff with a jack.
Remove the speedo sensor plug.
Unbolt the diff rear mount.
Unbolt the diff(4 19mm bolts on the top)
Lower diff and remove.
As Mr Haynes says,re-fitting the replacement is the reverse of fitting...
Please note that even small case diffs are heavy and an arkward shape to lift whilst laid on your back under the car.
Two sizes of diffs are fitted to E30,we refer to them as 'small' and 'medium',identify by the number of bolts holding the rear cover plate on,small has 6,medium has 8.
Ratio is identified by a tag attached to the diff rear cover.
B4UR
Fri Oct 30, 2009 10:23 pm
ok doesnt sound to bad where would i find the differet ration diff a 318? or are they the same?
B4UR
Fri Oct 30, 2009 10:26 pm
or even different ratio**
**BANNED**
Fri Oct 30, 2009 11:01 pm
B4UR wrote:or even different ratio**
4.1 is stock on 320i.....this gives 65mph at 3000rpm.
No point in going any higher IMO.
Expect to pay around £25-50,and they are heavy to post,so look for a local one!
mrLEE30
Sat Oct 31, 2009 4:42 pm
just did 222 miles on a full tank in my 325 all motorway but a steady 85
also just learnt that my speedo is in km and my tachometer in miles :mad:
**BANNED**
Sat Oct 31, 2009 5:32 pm
mrLEE30 wrote:just did 222 miles on a full tank in my 325 all motorway but a steady 85
Well there's a thing!
I always thought that the tachometer measured engine speed in revolutions per minute....
ChemicalAl
Sat Oct 31, 2009 6:40 pm
I get approx 250-320 from a full tank in my 325i (Depends on how many times I need to visit my needy mother in Glasgow in a week). I know this to be true, because I always reset the counter - bit of a saddo, but I don't have a trip computer like my E46 and like to know these things.
From the above posts I'm very happy with this :cool:
My 330i gives me 29mpg combined, but then maybe I drive both like a girl! :gay:
1987 E28 528i Diamond Black 74k
1986 E28 525e Saturn Blau 72k
1988 E28 525i 56k
1987 E28 525e 51k
1991 E32 730i SE Granite Silber 75k
1988 E30 316 Black 81k
1992 E30 318i Touring Diamond Black 43k
1990 E30 325i Touring Alpine White 2 65k
1986 E30
benjy
Sat Oct 31, 2009 10:09 pm
Ive just managed 78.6miles on 20 sheets @ 106.9 a ltr........ :?
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
sideshowbob
Sat Oct 31, 2009 11:00 pm
My 325i convertible auto recently returned 33mpg on a round trip to Devon. This was a mixture of fast country roads, motorway and 'A' road driving. I thought this was pretty good for a 17 year old car. My daily drive a BMW 330d has averaged 45 mpg over 150,000 miles most of this at 85 mph on motorways ....just shows how things have changed.
kitch
Sun Nov 01, 2009 4:43 pm
my 320 gets about 50to60 miles off ten pounds how ever i drive it
fuzzy
He who sleeps with "Gingers"
Sun Nov 01, 2009 4:45 pm
benjy wrote:Ive just managed 78.6miles on 20 sheets @ 106.9 a ltr........ :?
i got mileage than that of a 330bhp cossie.
benjy
Sun Nov 01, 2009 7:18 pm
Must be my right foot then cos ive never had a car that was good on fuel :P
I certainly dont drive like Misss Daisy :wink:
KimH
Sun Nov 01, 2009 9:14 pm
I can get 440 miles from a 325 Manual Touring between fills if I drive slowly and stick to motorways; 250 if I enjoy the A roads; much-much less pottering around town.
Just loose the lead right foot.
Yes a modern Diesel will do more miles per gallon. But factor in depreciation, not to mention the fun and pride in driving a modern classic, and a cherished E30 will be a good investment.
bpowell555
Sun Nov 01, 2009 11:01 pm
440 miles on a tank??! 8O Is that a standard fuel tank? I once got 275 but normally 240 ish, though never a long run on the mway ... always take the derv for that :roll:
N00b
Sun Nov 01, 2009 11:33 pm
bpowell555 wrote:440 miles on a tank??! 8O Is that a standard fuel tank? I once got 275 but normally 240 ish, though never a long run on the mway ... always take the derv for that :roll:
My 325 touring is running too rich, and I had no problem getting 325-350 miles from 46 litres.
Sun Nov 01, 2009 11:43 pm
mpg ? :pff:
just stick another £20 in when it gets near the red , :D
blue30
Mon Nov 02, 2009 8:47 am
I used to average about 330 to a tank on my 320, which I think is better than most of them manage! I had a long diff in it, new temp sensors, lots of servicing love etc. Setting the valves made a big difference too, like 40 miles per tank difference :o
George
Mon Nov 02, 2009 9:43 am
My record is 310 miles on a full tank until the empty light comes on.
Filling from 'the light' to full is about 45 litres which given the mileage, equates to approx 30mpg.
b4gga83
Mon Nov 02, 2009 11:43 am
I get 200 -250 miles to my 50 litre lpg tank, 18 mpg to 22mpg from my 325i. Which equates to 40.5 mpg to 49.5 mpg as per litre I only pay 0.47p!
Jozi
Mon Nov 02, 2009 12:42 pm
I've averaged 240miles from my last 2 tanks. worked it out at about 26mpg, M42 engine. It's pretty poor I think :(
stonesie
Mon Nov 02, 2009 4:23 pm
I'm getting about 24 - 26mpg average from the 2.8, it dosen't seem to matter how i drive it though, driving like it's icey all the time only gained me 20 miles over a full tank, so why not have some fun? :twisted:
Just noticed it's the same as Jozi's M42 :eek:
Jozi
Mon Nov 02, 2009 4:26 pm
I should have gotten a M20 engined touring :(
I don't even drive it that hard, there's the odd bit of using all of 2/3 gear but generally not gunning it.
Trying to get to the bottom of it in another thread.
djk
Mon Nov 02, 2009 9:37 pm
I average 28mpg in the 320i moredoor, best 38, worst 21 iirc. Town driving is the killer, and to get over 30 it has to be the m/way or dually and not too quick, anything over 80 and I might as well have left more time and taken the scenic/twisty/fun route.
