Stereo cuts out when loud
Posted: Thu Oct 22, 2009 4:12 pm
by beamer-boi
My jvc stereo keeps cuttin off when I put it loud what do people think the problem is?
Re: Stereo cuts out when loud
Posted: Thu Oct 22, 2009 4:13 pm
by beemerbird
Dry joint somewhere? Taste filter cutting in? :wink:
Posted: Thu Oct 22, 2009 4:14 pm
by pac1982
Do you have a subwoofer if so your power supply or earth is not good enough also some head units require a better power supply than the standard one that comes as part of the loom.
Try running a power supply direct from your battery to the head unit and remember to put a fuse in
Posted: Thu Oct 22, 2009 4:17 pm
by jenad
Your Headunit won't work with the E30 wiring of the speakers. They share one ground.
Posted: Thu Oct 22, 2009 4:20 pm
by beamer-boi
Yer I do have a subwoofer but I disconnected it n it still does it so gna run a wire with a in-line fuse directly to it to see if tht works
Posted: Thu Oct 22, 2009 4:22 pm
by beamer-boi
jenad wrote:Your Headunit won't work with the E30 wiring of the speakers. They share one ground.
so what do I need to do to make it not cut out?
by pac1982
Are you sure i've ran the same head unit in both my E30's with no problems its an Alpine CDA7876RB
Posted: Thu Oct 22, 2009 4:23 pm
by pac1982
beamer-boi wrote:Yer I do have a subwoofer but I disconnected it n it still does it so gna run a wire with a in-line fuse directly to it to see if tht works
I'm fairly confident it will sort your problem out, do the lights flicker on your head unit if so running a direct power lead to your unit should also cure this as well
Posted: Thu Oct 22, 2009 4:30 pm
by jenad
pac1982 wrote: Are you sure i've ran the same head unit in both my E30's with no problems its an Alpine CDA7876RB
Yes. :-)
It depends upon different things. A premium soundsytem has always shared grounds. Non-soundsystem does until the changig of the radio plug to the new version.
A radio connected to the factory-made wiring can show several symptoms. Overheating, scratching noises and so on.
Easy way to fix it is using new wires to the speakers.
Re:
Posted: Thu Oct 22, 2009 4:32 pm
by pac1982
Really? my current set-up has had all the speakers re-wired and the speakers are also amped but on my old e30 i was just running OE speakers and an OE loom plugged in to the same head unit and had no problems what so ever :?
Posted: Thu Oct 22, 2009 4:36 pm
by jenad
Did you have the large radio plug with 17 pins?
Maybe the Threadstarter can tell us a little bit more? Speakers have still the original wiring?
Posted: Thu Oct 22, 2009 4:39 pm
by pac1982
jenad wrote:Did you have the large radio plug with 17 pins?
Standard ISO connection which was OEM as far as i'm aware
Posted: Thu Oct 22, 2009 4:45 pm
by jenad
At least in germany, the E30 came never with ISO. Early models had DIN Speaker plugs and seperated wires. Late models came with the large 17 pin BMW plug, which was used in later BMW models as well.
Posted: Thu Oct 22, 2009 4:49 pm
by pac1982
jenad wrote:At least in germany, the E30 came never with ISO. Early models had DIN Speaker plugs and seperated wires. Late models came with the large 17 pin BMW plug, which was used in later models as well.
Prehaps i'm wrong i've only had two E30's first one had ISO which looked standard but i have to admit my current e30 had terrible excuse for wires behind the headunit
Posted: Thu Oct 22, 2009 5:07 pm
by jenad
A lot of cars have. I used a BMW wiring loom to retrofit the ISO plugs for my Traffic Pro.
Posted: Thu Oct 22, 2009 11:18 pm
by beamer-boi
yer stndard wiring still jus up graded front n rear speakers
Re:
Posted: Thu Oct 22, 2009 11:27 pm
by Barx325i
It may be cutting out to avoid clipping try running a permanent live directly from the battery..
Can you fettle the crossover on your headunit?
