Anyone know what these Manifolds are from?
OBs
Thu Oct 15, 2009 11:57 pm
I bought them some time ago, they are from a BMW but am unable to to find out which model they are for, I have tried Google and Realoem but have had no joy.
Part number's: 11621318211 / 11621318210
Stamped with BMW and made by Bischoff
Thank you
OBs
Fri Oct 16, 2009 1:04 am
sihooker
Fri Oct 16, 2009 1:08 am
E34 M5??
OBs
Fri Oct 16, 2009 1:14 am
This is what I was lead to believe Si, but have been informed they are not... I checked on Realoem and the picture is totally different.
sihooker
Fri Oct 16, 2009 1:22 am
It was the air pipes near the gasket faces that made me think that... :?
e21Jason
Fri Oct 16, 2009 1:26 am
real oem pic's are not 100% try google for images
Jason
Fri Oct 16, 2009 10:05 am
e21Jason wrote:real oem pic's are not 100%
Correct! The realOEM/ETK picture is just to identify an exhaust manifold - it could show a cast iron one.
JWaller360
Fri Oct 16, 2009 10:50 am
slightly O/T, what are those air pipes for, crankcase venting?
benjy
Fri Oct 16, 2009 11:03 am
The pics on my OEM look fairly close Andy........ But those part numbers dont seem to exist :? E34 M5 part numbers are close ...........
HTH :D
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
sihooker
Fri Oct 16, 2009 11:56 am
JWaller360 wrote:slightly O/T, what are those air pipes for, crankcase venting?
They are connected to an air pump and it's to reduce the emissions by mixing air with the exhaust gasses to create carbon dioxide and water instead of carbon monoxide. :D
sihooker
Fri Oct 16, 2009 12:06 pm
I've got a pic of an S38 manifold set-up in front of me from a 3.6 M5 and there's not much difference. The caption reads that the 3.8 version is very similar to this, so i would say it's from the 3.8 version..
OBs
Fri Oct 16, 2009 6:39 pm
Thanks for the replies guys... Oh and Ben :snigger:
OBs
Fri Oct 16, 2009 7:05 pm
sihooker wrote:I've got a pic of an S38 manifold set-up in front of me from a 3.6 M5 and there's not much difference. The caption reads that the 3.8 version is very similar to this, so i would say it's from the 3.8 version..
Thank you, I have just browsed through a few pages and I think your right, probably the 3.8 verson...
:thumb:
sihooker
Fri Oct 16, 2009 7:32 pm
No probs :D
