rear bumper removal
Posted: Wed Oct 14, 2009 9:59 pm
by ScottEgg
ok chaps, should be easy but how do I do it?
Re: rear bumper removal
Posted: Wed Oct 14, 2009 10:02 pm
by georgen
Have a look under the rear valance. You'll see 4 x 13mm's that hold the two rear brackets on. Unbolt these, and the bumper should just slide off.
Maybe best to have a mate / long suffering Mrs to hold the bumper as you unbolt.. :thumb:
Posted: Wed Oct 14, 2009 10:04 pm
by gooner1
On what car Scott :?:
Posted: Wed Oct 14, 2009 10:09 pm
by E30BeemerLad
under the bumper you will see a round hole about level with the light cluster on each side, there is a star drive type bolt in there, undo these bolts and then pull the bumper back towards you and off it comes
Posted: Wed Oct 14, 2009 10:56 pm
by mrLEE30
the above advice is only specific for the correct model!! if yours is a facelift then you normally need a T55 torx drive, look under the bumper and you will see them, remove the two and slide the bumper toward you. if you look in the wiki pages under fitting tech 2 bumpers it is explained better
Posted: Thu Oct 15, 2009 12:30 am
by Brianmoooore
Early facelift cars have cap bolts that need a 10mm hex driver, and the later ones have T55 torx, as Lee says.
If the last person to remove the bumper had no idea what copper grease is for, and torqued the bolts up fully, instead of lightly, then resort to georgen's advice. Only three of the nuts are under the car though - one is in the boot.
Posted: Thu Oct 15, 2009 9:17 am
by ScottEgg
many thnaks chaps, the car is an 88 Tech 1.
Posted: Thu Oct 15, 2009 10:31 am
by gannetboy
On chromie cars... one 10mm bolt either side of the car near the bumper end caps (accessible behind the carpet in the boot) and two 13mm bolts accessible by reaching up and under the rear valance.
