rear bumper removal
ScottEgg
Wed Oct 14, 2009 9:59 pm
ok chaps, should be easy but how do I do it?
georgen
Wed Oct 14, 2009 10:02 pm
Have a look under the rear valance. You'll see 4 x 13mm's that hold the two rear brackets on. Unbolt these, and the bumper should just slide off.
Maybe best to have a mate / long suffering Mrs to hold the bumper as you unbolt.. :thumb:
01' 330ci Sport
02' 530i Sport Saloon
52' 330i Individual Touring
gooner1
Out humping Reindeer
Wed Oct 14, 2009 10:04 pm
On what car Scott :?:
Wed Oct 14, 2009 10:09 pm
under the bumper you will see a round hole about level with the light cluster on each side, there is a star drive type bolt in there, undo these bolts and then pull the bumper back towards you and off it comes
mrLEE30
Wed Oct 14, 2009 10:56 pm
the above advice is only specific for the correct model!! if yours is a facelift then you normally need a T55 torx drive, look under the bumper and you will see them, remove the two and slide the bumper toward you. if you look in the wiki pages under fitting tech 2 bumpers it is explained better
Thu Oct 15, 2009 12:30 am
Early facelift cars have cap bolts that need a 10mm hex driver, and the later ones have T55 torx, as Lee says.
If the last person to remove the bumper had no idea what copper grease is for, and torqued the bolts up fully, instead of lightly, then resort to georgen's advice. Only three of the nuts are under the car though - one is in the boot.
ScottEgg
Thu Oct 15, 2009 9:17 am
many thnaks chaps, the car is an 88 Tech 1.
gannetboy
Thu Oct 15, 2009 10:31 am
On chromie cars... one 10mm bolt either side of the car near the bumper end caps (accessible behind the carpet in the boot) and two 13mm bolts accessible by reaching up and under the rear valance.
