exhaust manifold fitting
Posted: Fri Oct 09, 2009 4:59 pm
by garth
Hello there I was wondering if anyone has any tips for fitting a 6 branch manifold?
I was wondering if the best way to do it would be to undo the exhaust side engine mount and jack up the engine, as does this give you enough room to get the pipes in?
Thanks for your help
Ian
Re: exhaust manifold fitting
Posted: Fri Oct 09, 2009 6:22 pm
by daimlerman
I found it impossible to feed the rear set in without lifting the engine off the o/s mount.
Doublejointed fingers help with the manifold nuts as well,make sure that there is no-one with a swearbox within earshot!
Posted: Fri Oct 09, 2009 10:31 pm
by gooner1
daimlerman wrote:I found it impossible to feed the rear set in without lifting the engine off the o/s mount.
It is possible to get both headers in together, you need to get them in position and then just drop them.
Also do all the nuts up evenly. There is a guide somewhere, i, ll see if i can dig it out.
Posted: Fri Oct 09, 2009 10:37 pm
by gooner1
Here you go garth, assume it,s the same for all 6 branches.
http://www.e30zone.net/modules.php?name ... &start=100
HTH.
