Old/new bumpers info+electrical issue
Posted: Thu Oct 08, 2009 4:05 pm
Probably covered a million times, but it's hard to search for this one, it gives me all the wrong results.
Anyway, my car is a '85 320i, I have to change both front and rear bumper, front lip and right rear light. So I was thinking to upgrading to facelift bumpers and lamps.
What kind of work is required to fit these and what would I need?
Cheers.
THe other question I have concerns my ignition timing/distributor, it's been horrible the last couple of days.
The car has no power under load, it only generates power on very small load/downhill. Both hot and cold. It bangs on both intake and exhaust. I checked for vacuum leaks from the dizzy, there aren't any. I disconnected a small valve going into the distributor and it behaves exactly the same with it disconnected. Any clues to what's going on?
Thanks.
Cheers.
Thanks.
