eta krank/rev
Posted: Wed Aug 10, 2005 1:20 pm
by nikos
what is the max. rev for the 2.7 conv. without breaking the motor?
anyboby knows? thank you
Posted: Wed Aug 10, 2005 1:24 pm
by bigdek
read somehere about 6000 max
Re: eta krank/rev
Posted: Wed Aug 10, 2005 1:40 pm
by Karan
nikos wrote:what is the max. rev for the 2.7 conv. without breaking the motor?
my 2.7 had a new eta crank in it when it was built and has 90k miles on it in a high state if tune and it hasnt broken yet and can spin up to 7k nicely. but i dont bother and just change at 6k max usually
Posted: Wed Aug 10, 2005 2:05 pm
by Templ8e30
I heard that the eta crank is safe up to 6200rpm continuous. Above that the crank can twist between the webs.
I usually change around 6000 as well.
Cheers,
Iain T
Posted: Wed Aug 10, 2005 2:26 pm
by M5pilot
Karan's has been revved passed 6500 alot and it hasnt had a problem.
Posted: Wed Aug 10, 2005 2:46 pm
by Karan
as long as the crank and everything was balnced and tolerances were spot on when the engine was assembled i dont see a problem in revving way past 6k
Posted: Wed Aug 10, 2005 6:15 pm
by Simon13
C2's had the steel crank for a reason!!!
Posted: Thu Aug 11, 2005 12:43 pm
by Templ8e30
:yeahthat:
Cheers,
Iain T
Posted: Fri Aug 12, 2005 4:42 am
by nikos
thank you everybody
I set the rev limiter on 6200 and see you in two weeks time, vacation time has arrived
Nikos
Posted: Fri Aug 12, 2005 8:46 am
by rowemeister
Mine spins up to 7000 and I am convinced it will go past that.
Maybe its because Hartge forged there own crank.
Im sure M5Pilot will know!
