How to remove Diff Bush?
tim_haynes
Thu Oct 01, 2009 4:55 pm
Hi Guys, i have a lsd but it needs the bush replacing badly, could someone tell how you do this and what is the best replacement to buy for track use?
Any help would be great thanks.
Tim
rix313
Thu Oct 01, 2009 4:58 pm
The crude way is with a blow torch and burn the bugger out of there.
A good replacement for the track is a stiffer Powerflex jobby.
You can get the Powerflex diff bush from here: http://www.zonemotorsport.co.uk/store/s ... ex_e30.htm for £20 odd I think, cheapeast around and Paul is a legend :thumb:
**BANNED**
Thu Oct 01, 2009 5:04 pm
Sophisticated way is to use a hacksaw,feed the blade through the centre hole and cut it including the outer steel bush.
Polybush is dead easy to fit.
Z3M rubber bush is an alternate upgrade,but it will require a press to fit.
Youth is wasted on the young.
tim_haynes
Thu Oct 01, 2009 5:13 pm
Thanks guyS!! i thought it had to be brutal haha!
Will get a price on z3m one if not powerflex fine!
bimanut
Thu Oct 01, 2009 5:26 pm
you`l be there all day using a hacksaw,the way i got mine out was to cut the rubber part out,then carefully nick the steel coller out with a small grinder then heat it up a bit with a torch and started nockin it in with an old screwdriver to get the steel to buckle in on its self then it just started to drop through. replaced it with a polybush which is a dodle to put on
clarko74
Thu Oct 01, 2009 5:43 pm
I did mine with a hacksaw and it wasn't too hard at all. I replaced it with a z3m bush and managed to press it in with a big vice.
clarko74
suzie650
Thu Oct 01, 2009 6:34 pm
It can also be pressed out...
probably not with a vice, though.
mrLEE30
Thu Oct 01, 2009 6:36 pm
it should be pressed out!!
suzie650
Thu Oct 01, 2009 7:05 pm
hence the [...]
Jon_Bmw
Dangerous when thinking
Thu Oct 01, 2009 8:11 pm
Quite a few people have experienced cracked backplates when pressing new bushes in. I am not sure if this is 'ham-fisted-ness' or a proper problem. Try not to be to gun-ho with the mallet anyway. :)
tim_haynes
Thu Oct 01, 2009 10:06 pm
Thanks guys for all the info will let u no how I get on;) :)
tim_haynes
Fri Oct 02, 2009 1:35 pm
sorry guys just one quick question,
what is the difference between the 325i diff bush and the z3 m? they both fit exactly the same? one is stronger?
DHFiS
Fri Oct 02, 2009 2:32 pm
tim_haynes wrote:sorry guys just one quick question,
I think thats right. The z3 is an upgrade but not as easy to fit as a 2 piece polybush.
bimanut
Fri Oct 02, 2009 4:13 pm
polybush deffo the way forward cuz if for some reason or other you have to change it again it`ll just come apart when the end plates are removed.
A chimp could fit these!
Fri Oct 02, 2009 4:16 pm
you have to be very careful with a vice as the back plate is only ali and it crack either rendering the backplate scrap!
A press to push the old and new ones is the proper way really.
ZM3 bush although is expensive is designed to keep 320bhp in check and is well up to the job
tim_haynes
Fri Oct 02, 2009 6:17 pm
ok thanks guys, sorry i sound like a monkey!! :)
tim_haynes
Fri Oct 09, 2009 11:52 am
New Z3M Bush in, used all your advice. Thanks! :D
Joshy
Sat Oct 10, 2009 2:25 pm
So a vice is 150% needed for this job? Is there not anything a budding road side mechanic like myself could do?
I'm thinking hammer time?
Sat Oct 10, 2009 3:24 pm
Diff bush in the freezer, backplate in the oven. Lay the backplate on a wide piece of flat wood, lay the bush in place, and tap it in SQUARE with another block of wood and a hammer.
