E30 325i engine judder between 2000 - 3000 revs??
nickbentley
Sun Sep 13, 2009 12:15 pm
Hoping someone can offer me some advice on what may be causing juddering / vibration which is most noticable between 2 and 3000 revs. It almost feels like power is being delivered unsmoothly.
Above 3000 revs it isnt really noticeable. Its most obvious in 3rd-5th, and sometimes in 2nd it feels like it 'kangaroos', but i dont know if this would be a different problem?
Any suggestions welcome. Cheers.
zaust
Zone day release
Sun Sep 13, 2009 12:18 pm
Hard to say on this one fella. Normally things like this are down to distriutor cap and rotor. But would be looking for air leaks too.
M30 Tech 1 Touring on gas.
e30bmlover
Ac Schnitzer prophet
Sun Sep 13, 2009 12:19 pm
try the basics first... leads dizzy and rotor.. and plugs.. i would replace the lot if you havent done so already..
nickbentley
Sun Sep 13, 2009 12:26 pm
OK Great, thanks for the quick responses.
I forgot to say that it doesn't seem to happen when accelerating, more just when cruising at constant speed. Don't know if this affects what you think it may be?
e30bmlover
Sun Sep 13, 2009 12:29 pm
check the dizzy and rotor for signs of deteriation... then go from there.
Martinaston
Sun Sep 13, 2009 2:48 pm
Whats the milage on the car ?
For a few more answers do a search for "kangeroo" on the technical page.
There is NO nucleus.
nickbentley
Sun Sep 13, 2009 4:30 pm
Its just turned 100k Miles.
Will have a look at that page, thanks
rallye_turtle
Sat Oct 24, 2009 7:59 am
Nick, did you end up sorting this problem? The reason I ask is that my e30 sport has just started doing the exact same thing. Car accelerates fine but when cruising between 2k-2.5k revs the engine seems to judder causing the car to kangaroo. So far i've replaced the rocker gasket and have checked all vacuum hoses, all seems fine, also put news sparks too and still no change.
Wayne
nickbentley
Sun Oct 25, 2009 12:55 pm
Hi Wayne,
No i still havent actually got around to doing anything with it yet! Been too busy with work etc! Will try and have a look at it this week though. Let me know if you manage to sort yours though.
Best of luck
Nick
rallye_turtle
Mon Oct 26, 2009 8:09 am
nickbentley wrote:Hi Wayne,
Best of luck
Nick
I'm hot on the case at the mo, to date have done the following:-
- Checked all vacuum air hoses around AFM, TBH & inlet Mani (All are good)
- Replaced rocker gasket as there was a slight oil leak (This helped but only very slightly.
- Removed oil filler cap while engine running which caused it to judder a bit therefore indicating there are no air leaks (I Think :? )
- Tested coil primary and secondary resistances which were fine.
- Renewed all sparks. At the same time inspected all ign leads which were good.
- Removed and inspected dizzy cap & rotor, no cracks, cleaned and removed oxidation on contact points. This appeared to help but again only very slightly.
Bit stumped as to what else I can check, perhaps swap out ECU for a known working one, and maybe check continuity of wires between ECU and engine sensors (ie thottle position sensor etc).
The investigation continues :?
bpowell555
Tue Jul 06, 2010 7:00 pm
I have this exact scenario - any more ideas?
1990 325i touring
She's a minter! Best 3 years of my life - bye bye baby :D
jimmymig
Wed Jul 07, 2010 4:17 am
Ihad the same problem about a year ago changed fuel filter and juddering stopped
bpowell555
Wed Jul 07, 2010 7:23 pm
I was thinking to have a go at the fuel filter. Will try that first - has not been done in a year (12k miles) - what's the service interval supposed to be? Sorry don't have haynes handy :D
edit... I do tend to run it quite low which could reduce the lifespan ...
1990 325i touring
bpowell555
Fri Aug 20, 2010 10:03 pm
Reckon its a worn part of the track on the AFM - tell me I'm wrong :cool:
1990 325i touring
eddieg
Sat Aug 21, 2010 3:46 am
DME Relay and fuel pump relay?? The DME relay provides power to the ECU. My BMW mechanic who was at a main dealer when e30s came out told me that they had many problems like this caused by dodgy relays and he had to change out lots and lots. On my 318i and 318is these relays sit behind a long thin plastic cover in the engine bay just below the windscreen wipers. About 20 quid in total from main dealers. Or swap out and test with ones known to be OK from another car?
bmw9818
Sat Aug 21, 2010 11:40 am
Ht leads my car used to that well when i was cruisin they were completely gone after I changed them it was fine
