REAR SUBFRAME BUSH REMOVAL TOOL
Posted: Sat Aug 22, 2009 11:53 pm
by ETERNITY
Hi dudes i need to change my rear subframe bush but apparently a special tool is required to do this..
were can i get one from(special tool), because i dont fancy paying £70- 100 to someone to change my bush..
Re: REAR SUBFRAME BUSH REMOVAL TOOL
Posted: Sun Aug 23, 2009 12:03 am
by Cook318IS
seem like a better idea to pay a specialist to do it now? Not a pleasent job either i dont think.
http://www.ccw-tools.com/Sealey/Vehicle ... -74-12046/
Posted: Sun Aug 23, 2009 12:06 am
by ETERNITY
lol i see
is 70-100 standard for changing this
Posted: Sun Aug 23, 2009 12:08 am
by Cook318IS
a garage with the tool - yes. Cost me £100 for a local bmw specialist to do it for me (only specialist for about 40+ miles - i think he knows this too so charges a lil extra) IIRC i remember reading posts on here of people taking around 8 hours to do the job themselves without the tool 8O
Posted: Sun Aug 23, 2009 12:11 am
by ETERNITY
damm,
sweep wants to do it for £70 max, i will contact him
Posted: Sun Aug 23, 2009 11:48 am
by Daf318is
If you're really intent on doing it yourself you could alway drop the rear beam off. It's not too bad a job really if you're prepared to get your hands dirty! :)
The bushes are relativly easy to get out when the beam is off the car :)
Posted: Sun Aug 23, 2009 12:12 pm
by Avtovaz
it isnt that hard to do yourself, i did the ones on the back of the compact and replaced them with hard black polly bushes.
Deffo take off the rear beam, it isnt that big of a job, then put the beam in a vice. Heat up the aluminum insert inthe middle of the bush with a blow tourch, get it as hot as you can from both ends. Then i had a big adjustible spanner, the ally insert has flats on the sides, so i tried to turn the ally bush until the glue snapped and knocked it out.
Then i nicked the side of the outer bush with a hacksaw, making sure i didnt damage the beem. One side i used a hammer and chisel to rip the bush out, and the other i used an air chissel, much easier!
You could alsoways get a second hand beam if you are worried about doing it in a space o time... It took me about 4 hours to do in all, thats taking the beam onand off aswell!
Posted: Sun Aug 23, 2009 4:02 pm
by daimlerman
I pulled the entire rear suspension off the project cabbie to deal with all the bushes;
Bushes are still in the rear beam there,I am dealing with the easier trailing arm one's first!Same method was used,burn the rubber until the centre bit will drop/bash out,then you need to support the beam whilst you cut the outer steel liner out.
You can just see the remains of the beam bushes at the top of this piccie..
Local garage charged £10 to press the new bushes in for me.
This is not quite a straightforward DiY job,OK if you are working on a project like I am,but on my to running cars I paid my local BMW indipendant specialist £115 per car.
Posted: Sun Aug 23, 2009 4:09 pm
by ETERNITY
i will let sweep(zoner) do it for me..
he has the tool
Posted: Sun Aug 23, 2009 6:00 pm
by daimlerman
ETERNITY wrote:i will let sweep(zoner) do it for me..
he has the tool
Good choice,let someone else do the swearing!
Posted: Mon Aug 24, 2009 1:00 am
by cliffybabe
heres my bush removal info
The tool kit with instructions on how to make the tool to what u need to do
You put the kit together to make up the puller and installer
Bush puller made up
The bush puller in use
On this pic it shows how the puller has a metal lid that locks around the top of the bush that pulls it out
On this pic u can see how the device also uses the sill of the car for the removal tool
The bush installer made up
The bush tool installing
If u look the lid of the tool overlaps onto the rear beam for better pulling
Once pushed all the way in it looked like this
All in all a cracking tool, but to be honest all though I was using the tool it was a still a bitch of a job as the metal collar on the old bush on the left had corroded to the car and took a lot of swearing and smashing to get the beam to drop down however with out the tool there is no way I could of done it
link to thread
Posted: Mon Aug 24, 2009 2:17 am
by ETERNITY
SWEEP???
Posted: Mon Aug 24, 2009 2:19 am
by armanib
bss325i has the tool
Posted: Sat Oct 03, 2009 7:50 pm
by Daz318is
Hi
May try to make one
Darren
Posted: Sat Oct 03, 2009 10:16 pm
by leeparkes
Town325i made his own bush removal tool using threaded bar an various large washers.
Posted: Sat Oct 03, 2009 10:24 pm
by sweep
Expensive arnt they
Posted: Sun Oct 04, 2009 1:35 am
by Dave_M3
Pretty pricey alright especially as you still need to do the worst part of the job in getting the beam detached from the car to be able to use them.
It's easy enough once you get the beam away from the car to change them as all you need is a little air-chizel and jigsaw to cut the bush out :D
My preferred option of doing them is pick up a second hand beam and trailing arms. Refurb the whole lot or at least a lick of paint with new pads, shoes, discs and lines etc and put the whole lot on to have the whole rear end finished of problems as lets face it, brake lines on our cars as well as all the bushes start to go at the same time and a nice shiny black rear subframe and trailing arms look great! 8)
