number plate light
Posted: Sun Aug 16, 2009 12:34 am
by telboy
number plate light keeps flashing on the check panel every time i put the lights on ...but both bulbs are fine..any ideas cheers
Re: number plate light
Posted: Sun Aug 16, 2009 9:48 am
by daimlerman
Takes only a tiny voltage drop to set the telltale off,I have the same issue on one of mine,usualy after crossing a pothole in our wonderful Lincolnshire back roads
I expect that the light flickers and that's enough.
You could try another pair of bulbs,good quality one's are better,they cause less voltage drop.
Another possible cause is muck and/or corrosion on the connectors.
Posted: Sun Aug 16, 2009 2:00 pm
by mrLEE30
check the actual holder is not corroded, clean it with seom emery cloth and bend the holder so they grip the bulb better.
Posted: Sun Aug 16, 2009 2:12 pm
by telboy
cheers fellas will give it a try
Posted: Sun Aug 16, 2009 2:49 pm
by hennabm
Does sound like an earthing fault - don't forget to clean round the screw holes as the provide the earth.
Posted: Sun Aug 16, 2009 3:19 pm
by telboy
turned out to be the plastic lens/holder itself ...it was snapped where it holds the terminal superglued it back works fine now......cheers fellas..................clever things these check panels ..even tells you the plastic has snapped
