Help with starting my e30 - E30 down! - Video included
Posted: Thu Aug 13, 2009 6:41 pm
by Mhiran
Ello,
Right, we are currently trying to start our beloved e30. We cannot figure out why it isn't starting, so i've uploaded a video onto youtube so some bright spark can hopefully diagnose the problem!
Cheers in anticipation!
Mhiran
Re: Help with starting my e30 - E30 down! - Video included
Posted: Thu Aug 13, 2009 8:14 pm
by tomislav
Well a battery capable of turning the engine over would be a good start. It really needs to be of brand new power. Then you can start diagnosing stuff.
What have you done to the car before trying to start it? Rebuild? Or is this how you bought it?
Posted: Thu Aug 13, 2009 8:46 pm
by Grrrmachine
That could be anything at all, not least a complete lack of battery juice.
So to start with, have you taken out a spark plug and grounded it to see if its sparking?
Have you disconnected a fuel line and bypassed the fuel pump relay to see if you're pumping fuel?
Have you done a thorough check of all rubber intake components for air leaks?
If you've got the three (air, fuel, spark) then it must be a more complex problem like a duff sensor, but ensuring you have the big three is a good place to start.
Posted: Mon Aug 17, 2009 2:15 am
by e30briyan
ive been working on this car aswell, we've replaced all the spark plugs and they are sparking, pumped some fuel directly into the engine and it fired not sounding too healthy but nevertheless it fired! does this mean a new fuel pump? or could it be a leak in one of the fuel lines? wheres the best place to start? cheers for the help
Posted: Mon Aug 17, 2009 2:38 am
by magpie
the fuel pump is my guess + battery.
put a direct 12v feed to the pump and crank it over with a good battery,
Posted: Mon Aug 17, 2009 12:19 pm
by e30briyan
cheers for the help guys, will give it a crack today and let you know how we get on!
Posted: Mon Aug 17, 2009 7:58 pm
by magpie
did it start then??
Posted: Mon Aug 17, 2009 11:23 pm
by Mhiran
got delayed, will let you know tomorrow!
Posted: Thu Aug 20, 2009 6:44 pm
by e30briyan
checked the fuse and its fine, also tried to jump connectors 30 and 87 and nothing happened, took the relay and tested it and its working fine, only thing i can think of now is pump, how much are they roughly and where's the best place for them euro car parts?
