320i - Which oil grade??
Posted: Sun Aug 02, 2009 7:05 pm
by Retrespect
What oil are people putting in their 320i e30? I've got some 5/30 in the shed and was wondering whether it would be suitable or not, or whether I should go for a different grade?
I've had a look at the stickys on oil, but they didn't answer my question. Maybe I didn't look hard enough?!
Re: 320i - Which oil grade??
Posted: Sun Aug 02, 2009 7:22 pm
by shedrool83
10/40
Posted: Sun Aug 02, 2009 7:30 pm
by stonesie
As above, i use that Vauxhall branded 10/40 semi synthetic mainly because i get it for £12 for 5 litres but have never had a problem using it.
Posted: Sun Aug 02, 2009 7:54 pm
by Retrespect
Would 5/30 be ok in mine? Can't be bothered spending any money if I don't need to
Posted: Sun Aug 02, 2009 8:44 pm
by Black_Potato
Its not ideal, its not the recommended grade. But will it explode day 1 - NO, could it cause premature wear in the medium to long term especially if driven hard - YES.
Posted: Sun Aug 02, 2009 9:10 pm
by djk
Semi synth 10w40 is the recommendation in the oil stickies. That's what I use!
Posted: Sun Aug 02, 2009 10:47 pm
by Brianmoooore
5/30's a bit thin, but it won't do any harm. I've used it in E30's before with no ill effects.
Posted: Sun Aug 02, 2009 11:33 pm
by Retrespect
djk I love your garage of cars !! Can't beat the twin headlights ! BMW get it sorted and put them back into the design !
Posted: Mon Aug 03, 2009 1:26 pm
by chris318i
GSF have a Fuchs brand semi syth 10/40 for less than £15 for 5 litres, thats what i've stuck in mine
Posted: Thu Aug 06, 2009 3:00 pm
by BadMoonRising
I used 10/50 which is for high mileage cars in my 320i. Is that ok?
Posted: Thu Aug 06, 2009 3:25 pm
by Brianmoooore
BadMoonRising wrote:I used 10/50 which is for high mileage cars in my 320i. Is that ok?
There's no such thing as a 'high mileage' BMW!!!!
!0/50 will be costing you a little in MPG. 10/40 is better.
Posted: Thu Aug 06, 2009 3:32 pm
by BadMoonRising
Cheers Brian
Won't do any damage if I use the bottle up tho?
Posted: Fri Aug 07, 2009 1:10 am
by Black_Potato
No harm at all..
At startup the oil will be the same viscosity at the 10w40 or as near as makes no difference, its just slightly more viscous at higher temps.. hence the higher 2nd number.
That extra viscosity means a little more drag which means the engine uses marginaly more power pushing the oil around. So.. very slightly less BHP and very slightly worse fuel consumption as a result.
