convertible hood motor
Posted: Fri Jul 31, 2009 10:17 pm
by bushwakka
i have a 1991 cabby with the power hood, which is being a bitch!!
i have noticed the bracket that the motor of the middle unit bolts onto has broken. is this bracket replaceable or is it a complete unit?
cheers
Re:
Posted: Sat Aug 01, 2009 10:32 am
by DaveD
Which bracket did you mean is it shown on either of these diagrams
http://www.realoem.com/bmw/showparts.do ... g=54&fg=10
this thread might give a little more insight
http://www.e30ic.com/powertop.htm
if it is the motor you can buy a new top half in steel for about £100
but more info needed
Posted: Sat Aug 01, 2009 2:43 pm
by bushwakka
thanks for the info. the part that is broken is on the motor that lifts the horse shoe, mounted in the middle of the boot.
its the plale that the motor and drive is mounted to, the plate that springs away when you operate the drive disconnect lever. it is broken at the pivot pin end.
cheers.
Re:
Posted: Sat Aug 01, 2009 7:21 pm
by DaveD
never seen one of those break before look on the first diagram and see if you can isolate the part...try Badboy007 or ceccotto who had some cab motor parts for sale first
Posted: Sun Aug 02, 2009 1:10 pm
by bushwakka
it is part of no.9 . where the motor and round black plastic drive unit is mounted.
Re:
Posted: Sun Aug 02, 2009 9:16 pm
by DaveD
part 9 is the motor?..so it sounds as though you need a new flap motor...try ceccotto or Bill at the e30 CENTRE on 07968852395
